Results 1 to 3 of 3
Thread: Lsa dyno
    Beyond Help Darkmanx's Avatar
    ft lauderdale fl
    Default Lsa dyno
    Switched from a tvs 1900 to a lsa and these are my results . Im running out of injectors when i get some new injectors ill do another run but these runs where not that bad.
    Nice. How much boost were those numbers from?
    ft lauderdale fl
    14 psi
