So, I want to have my throttle body ported......but my G8 is my daily driver.....So I was thinking about picking up a used throttle body......the big question is.......
What throttle bodies are interchangeable with ours......
V8 Muscle
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Plastic Cuttin' Bad Ass!
do what george said, that will be the easiest and cheapest way
2008 White Hot G8 GT
SLOWHAWK Tuned
My Garage
PS, to answer your exact question, you need a 90mm, drive by wire tb. G8s and Corvettes use them also any LS2 powered car. (ie, 05-06 GTO)
Ls2Portworks usually has cores, too, and does a good job
'09 SRM GT. Pedders/BMR bushings, Whiteline front swaybar, BMR rear sway bar, trailing arms, subframe connectors, Spohn rear LCA, GXP rear shocks, GTS wheel, Vector HSRK, Ls2Portworks throttle body, Vararam, GXP front Brembos, EBC pads, Russell brake lines, XXR wheels, Corsa catback with custom tips, hacked Atari gauges, V6 taillights/door handles, upgraded speakers, black window trim, blacked grilles, custom pin stripes,
