My G8 GT Build
Well, it's been a long weekend, but she's finally done! I decided to tear into it after I lost two AFM lifters and a timing chain dampener (which I wasn't aware of until I pulled the oil pan). Here's the list of mods...
Spectre Cold Air Intake now wrapped to reduce heat soak
Frankenstein Engineering Dynamics Stage 1 LS3 Heads milled .25
Frankenstein .660 Lift Double Over Valve Springs
Frankenstein 7.400" Hardened Pushrods
LS7 Lifters
LS2 Valley Cover
LS2 Timing Gear and Chain
Ls3 Rocker Arms with Trunion Upgrade
Frankenstein Spec'd Cam 228/234 .640/.620 119+6
Removed and Plugged Oil Pressure Relief
Circle D 3200 Stall Torque Converter
1 3/4" Longtube Headers
NGK BR7 plugs
MSD plug wires
Tuned by TXLSX
We took all of the accessories and the intake manifold off the first night, and Russell from Frankenstein came to help!
Then, we pulled the motor Friday morning and began breakdown.
Here's my timing chain dampener sitting at the bottom of the timing cover next to the oil pickup.
The cam...
The heads on...
Motor goin in...
Buttoning up the last few things...
The startup...
3 days of work. Done
Post Thanks / Like - 1 Thanks, 2 Likes, 0 Dislikes
