I am having a problem with my purchased tune, and I am not going to take it back to [butthead] to get it redone. I have HPTuners and a little experience, and I was hoping you guys could point me in the right direction.
The idle is set at 550 rpm which works nicely with my mods and (stock) convertor. The problem is that when I am slowing to a stop, the idle drops below 550 rpm momentarily, and then when the speedo hits zero mph, the idle suddenly jumps back up to 550.
This surge in the idle is disconcerting if you are not ready for it (and even sometimes when you are).
Is there an easy way to identify where to look to correct this issue? I'd be happy if the idle never fell below 550 rpm even when decelerating.
Thanks for any info!
