Results 1 to 10 of 13
Thread: Options for rebuilding Pedders Xa damper
    Senior Member solty's Avatar
    Ann Arbor MI
    Default Options for rebuilding Pedders Xa damper
    I searched the forum but could not find the contact in the US that can rebuild Pedders Xa dampers. I found few threads mentioning that Rob Wretched knows that contact but the info was never published. It is documented that this guy charges $100 per damper to rebuild them.
    I sent Rob a message, but would like to know if anyone else (CP?) knows of options to rebuild the Pedders Xas damper.
    If anyone here has some info, please post or pm me.
    2009 G8 GT Silver Metalic with Premium Onyx/red - Sunroof - Sport package - Vararam intake - DOD delete - Livernois 2C cam - Kooks Mids 1 7/8" - Corsa cat back - Pedders Xas - triple Gauge - Blue tooth module - VIM
    Feb 2014
    I talked to Rob a while back before I got lucky and found new inserts for mine. He told me to contact Feal Suspension in California. Im going to send my old ones back eventually.
    I've checked into it before and your West Coast USA rebuild option is your only real hope.
    80% of the enquiries I make here with Pedders end in disappointment and if that's "No Bull" then it must be a cow with a cock.
    Last edited by Crazy Paul; 07-29-2015 at 04:42 PM. Reason: Had a win, % upgraded from 90 to 80
    Ann Arbor MI
    Quote Originally Posted by evilG8cop View Post
    Thanks evilG8cop.
    I went on their site and it looks like they can do that. The scary part is it seems that to rebuild one damper cost $175 + $35 for inverted type which I believe the rear units are. So most likely $250 once shipping is included.....Dam you Pedders, where are you now that I need to use my lifetime warranty ;-)
    Ann Arbor MI
    Quote Originally Posted by Crazy Paul View Post
    90% of the enquiries I make here with Pedders end in disappointment and if that's "No Bull" then it must be a cow with a cock.
    LoL CP.
    Thanks for the quick feedback.
    Capitol City G8 G8V8's Avatar
    Jacksonville, FL
    I had a rear Pedders V8 Supercar coilover resealed after it started leaking from the adjustment knob shaft. I went thru Rob at Wretched. He made the arrangements and I shipped it directly to Feal. It cost the same as dealing with Feal directly. They fixed it in 3 days so even with shipping time it was pretty quick. It has been working fine.
    HSV E3 Bumper and Fenders
    VMS DoD-Delete with heads
    TVS1900
    RCR TB
    Kooks 1 7/8 Mids+SOLO Mach
    ZL1 Brakes
    Roto-Fab
    merca!!!
    The rears are not inverted. They are the "simple" setup.
    An inverted design has the shaft on the bottom protected by a outter tube housing.
    2008 GT-M. PBM, #885
    Ann Arbor MI
    G8V8, good to hear you had good results with them. I did call them and ask few questions, they are very helpful. He clarified cost to rebuild the Xa damper is $150 + shipping.
    Did you do one rebuild or the pair?
    Quote Originally Posted by G8V8 View Post
    Ann Arbor MI
    Ok, thanks for clarifying this BuildItYourself
    merca!!!
    If you get a contract for the guy who does the work let me know I need two top rear seals for a BC setup.
