Results 1 to 10 of 11
Thread: Picture of rear brake installation
    Jul 2015
    High Point NC
    Default Picture of rear brake installation
    Could someone post a picture of the rear brake system for 2008 G8 GT please.
    87 GN bolt ons Alky kit 12.10 @110 on Drs
    Moderator LDM's Avatar
    Mar 2010
    Cape Cod, MA
    Len
    Jul 2015
    High Point NC
    Oops with the rotor off, I would like to see the park brake assembly
    Mar 2010
    Cape Cod, MA
    Len
    Jul 2015
    High Point NC
    Super thanks so the parking brake assembly is kind of separate from the rotor.
    Great minds must think alike I'm doing a set of rotors and pads on mine also.
    Mar 2010
    Cape Cod, MA
    Yeah, the parking brake just uses the inner hub of the rotor as a brake drum. Those pictures are actually from a year ago when I upgraded my brakes.
    Len
    Jul 2015
    High Point NC
    Bad cv joint closest to the diff right rear. Is the axle nut a 36 mm? I guess you drop the 2 lower control arms? Do you yank the axle out of the diff, ie is the joint have a slip ring. Is it hard to find a rear axle. Thank you very much.
    merca!!!
    Yup just pull it out. I found it easy to remove the entire spindle and pull the axle out with it. Pop the inner axle stub out of the diff then remove the control arms from the spindle. An impact will take the outter axle nut off without problem.
    2008 GT-M. PBM, #885
    Jul 2015
    High Point NC
    What is the torque spec for the axle nut?
    Mar 2010
    Cape Cod, MA
    Len
