I put in 8 too. After what drained out I think I could have saved $6.00 and only put in 7.
Moderator
Chewy
I'm at a loss! I put on my camaro pan and pumped in 8qts like I'd been told it's take and when I got it level, ran through the gears, was at 118F and when we pulled the plug at least a qt or more came out. Is that right?
Sent from my iDevice using data nodes and algorithms.
Service manual spec for pan capacity is 6.0 qts for the G8 and 6.7 qts for the Camaro. If you put 8 qts in then I suppose 1.3 would've come out.
http://forum.grrrr8.net/showthread.p...l=1#post441830
Len
Thanks guys! I think we got it! Drove it for an hour and saw a high of 145 degrees for the trans. Shifts ok, but man, I need a smaller cam and lower stall.
Chewy
That is crazy talk.
this does not look like it's going to be fun
