Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 85
Thread: Checking,Filling,Changing ATF
  1. #61
    VIP Member Daniel Linnett's Avatar
    Oct 2010
    ArklaTex
    WHOLY SHIT. I was looking all over for some dipstick and fill tube. WOW. I knew GM was going to lubed for life transmissions but I didn't think they would do this. I think older transverse axle cars (and minivans) had them first.
    Great info thanks. Guess I won't worry about the tranny for a while then.
    You can buy a custom dipstick tube from a member here. I have one on my car. I will show it to you next time I am in town
  2. #62
    Beyond Help texn884's Avatar
    Helotes, Texas
    So when you need to change the transmission fluid you dont drop the pan anymore? You have to suck it out?
  3. #63
    Central Florida
    What's the recommended method for ensuring the car is level?
  4. #64
    Addicted Member Sephiroth's Avatar
    Dec 2010
    Suffolk, VA
    I use 4 stands of the same make/brand. Lift the car on equal levels by the number notches. I believe you can use a level on the pan itself to make sure it's level as well. If the unibody is raised on equal levels though, and your driveway/garage isn't un-level, it shouldn't matter.
    Been doing it this way on the 5speed ZF in the Audi, which has the same fill procedure. Make sure you jack it up decently high, and that you remove the fil plug on the side of the 6L80E *before* starting the car. Also make sure you have your pump tube inserted as well. The plug is *right* next to the exhaust, and I've already burnt my wrist once or twice trying to do it with the car on, and trying to put it back in after I was finished.
    remember to go through the gears after it reaches 30C and wait 1 minuite, otherwise you'll be greeted to 1-2Quarts of fluid escaping that shouldn't when you remove the fill plug. Don't ask how I know..
  5. #65
    Central Florida
    That won't work unless you have equally level lifting points. Since there aren't any real standardized lifting points.... I think I'll put a level on the door sill or the pan and get as close as I can.
  6. #66
    Dec 2010
    Suffolk, VA
    you would be resting the jacks on the crinkle pads, which are all level and parallel with each other. It came out level the 1 time I checked with an acutal level.
  7. #67
    Central Florida
    Quote Originally Posted by Sephiroth View Post
    I don't trust crinkle pads. I leveled mine on the pan, its warming up now.
  8. #68
    Dec 2010
    Suffolk, VA
    just took a look at this as you've peaked my interest enough to take a second look(and because I'm painting my calipers <_<).
    Using my method, the car is level and flat going off the side skirts, but the pan is not, and here's why;
    The 6L80E oil pan is @ an angle, so you absolutely do not want to level off the pan, leveling off the oil pan will create an overfilled situation. My suggestion would be to level off the sideskirts per your suggestion, or the crinkle pad method per mine.
    The rear tires will dropp more than the front, but this is because of the suspension geometry differences and not because the car is not level.
  9. #69
    VIP Member kendall.alston's Avatar
    Dec 2010
    Harker Heights, TX
    wow....this seems like a hassle.... good thing i read this before installing this transmission cooler...
    2009 Hot White G8 GT w/ Onyx/Red Int. Sport/Premium
    Show: Tint 25%-F 15%-R, Billet grill inserts, rockford fosgate audio, gxp diffuser, eibach pro springs,
    Go: Kooks 1 7/8 LT w/catted x-pipe, SLP loudmouf Axle Backs, BMR subframe connectors, bmr tunnel trace, BMR trailing arms w/ bushings, BMR adjustable toe rods, BMR adjustable control arms, billet prototype catchcan, Yanks 3200 stall, L92 Stage 2 heads, thunderracing custom cam 223/235 .610/.620 on a 115 LSA, Kenne bell BAP, magnacharger TVS 2300 w/ rotofab cai, Tuned by 21st Centurty Muscle Cars
    Murk...or be Murked! Protect Your Chest!
  10. #70
    Lucky SOB G8GT721's Avatar
    MA
    how many qts. for a dry transmission, i think its like 12.x but im not sure anyone.?
    should i stick with gm dex VI, royal purple or any other brands?
    2008 White Hot G8 GT
    SLOWHAWK Tuned
    My Garage
