2009 White Hot GT, Sport/Premium Pkg. w/ Onyx-Red Interior
Vararam, Kooks Mids w/ Cats, and custom tune from Modern Muscle
WeatherTech Floorliners, GM/Pontiac Trunk Liner
"Pilots are a different type of people." ~ Most Psychologists
Any one have a video of this? I can hear a noise but I think it may be pcv or something.
Sent from my mind using opposable thumbs.
I'll catch a vid this week. More noticeable with engine cover off. Injector maybe?
I've got this ( questionable tick)
http://youtu.be/Iq5RKNQKm5g
Not this (obvious ticking)
http://youtu.be/DXKeqVWdcxY
Removed the Pontiac arrow from the back no gouges and such first step in rebaging!
I tried some new oil at my last oil change. I usually use synthetic stock weight, what ever is on sale or AMSOIL for the 1st 50,000 miles. Now I have 84,000 miles, hard miles. It always had a rough sound valve train and I get the cold start lifter tap pretty bad if: it is winter or cold, if even just a little bit low of oil-even 1/3 of a quart low will make it louder, if it is even slightly dirty, usually it will start tapping after 3000 miles of oil use. A very respected buddy of mine suggested this newer type oil made especially for older cars with some milage. It is only a BLEND not full synthetic so it was much cheaper and I got it on sale at 3 bucks a quart!!! It is called DEFY, it is made by QUAKER STATE. http://www.quakerstate.com/#/motor-oil/defy
They say, "Quaker State Defy™ Synthetic Blend Motor Oil
Help virtually stop the aging process inside your engine.
Over time, all engines age and experience wear that could severely shorten engine life. Now there is a motor oil that can virtually stop wear in its tracks—new Quaker State Defy™ motor oil. Quaker State Defy is a synthetic blend motor oil that’s engineered to defy time by preventing 98% of future engine wear1—including camshaft wear and bearing wear. Quaker State Defy contains increased zinc anti-wear agents that target high-temperature and high-wear surfaces to help you get the most life out of your engine."
I really like it. Since putting it in I have noticed way less vavle train noise and as of yet(3300 miles) has not had the nasty cold start tap plus I gained back the 1 mpg I loss since using PEAK SYNTHETIC oil which I had 18 free quarts. Not bad for free but I would not buy that stuff.
The DEFY will be my new go to oil. I change my oil by color, not time or miles. It never gets black, I change when brown and starting to turn black. Usually 3,000 to 9,000 miles, depends on alot of variables obviously. Try it let me know what you think. DEFY I like it.
I did some rewiring on my AFR system. Slowly but surely getting ready for Darlington....
