When they tore the first engine apart from the lifter issue the engine was like so clean in side all the techs could not believe it I guess depends on driving which mine is all highway miles so I like the RP.
going to give the PZ a try in due for a change now in a few weeks I change my oil every 10-12K
2009 Panther Black Metallic "
The Black Rat"
Sounds so
GRRRR8 BECAUSE RACE CAR
Curt here
Chewy
From the tests I've read, RP is NOT the oil to use. I used Rotella 5w40 last year and put a good 100+ miles on that. I've vowed to use the car more this year though and I am thinking about the Penn ultra as well. I have Penn synthetic in my '17 Durango 5.7L and it seems OK. I'd like a 5W40 though for my stroker. I'm not sure it's necessary however.
Considering the extra forces you are putting on the mains and the extra loads across the cam - I'd recommend it - other than maybe moving to a 10-30.
Napalm
I want to keep the 5 because the bearing tolerances are still tight so I don't want to starve it any longer than necessary. I'd read that it's NOT a good idea to run a 10 on current engines for that reason. Back in the day when machining tolerances weren't as good, a 10W was necessary. This is why I went 5W40. I'll look for the Penn in it when I get there. Still a few months to go!
Chewy
Good advice
The Black Rat"
Sounds so
Curt here
Chewy thanked for this post
just ordered 10 quarts from walmart.com for $7.98 quart with tax and free to house shipping $86.18 Pennzoil Ultra Platinum 5W-30 Full Synthetic
The Black Rat"
Sounds so
Curt here
I can see where that might be true but I don't think a modern synthetic 10-30 has the same 0 degree pour points or shear viscosity of the older stuff. I'd have to check a spec sheet to be sure. so I mean that's always a good measure - check a spec sheet.
Then again with the dollars they also make a 0-40 or some such if it was really an issue.
Just in Walmart has the 5w30 Ultra Plat for sale here for 29.99 for a 5 quart jug
24.95 for the platinum 5w30
R.I.P. Charlie (Mr GRRRR8)
R.I.P. Chris (Panzer Leader)
MongosG8
Shit
The Black Rat"
Sounds so
Curt here
MongosG8
Says out of stock now, had it set to notify me when back on stock. You sure it was the 5w30 5qt jugs?
G8eraid
Yeah I was there yesterday ..Purchased the last 5 quart they had left on the shelf near me.
Too bad (1) 5 quart doesn't do it. But I changed my oil with Penz Platinum before I put my G8 away this winter.
It cost me 58.00 bucks with an ACDelco UPF48R filter back in November.
