Page 5 of 45 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 447
Thread: Magnuson 1900 Project- over-drive Cog, Porting, & Cutting out restrictions....
  1. #41
    Feb 2009
    Hope Mills, NC
    I have a scan log of Doug at the dragstrip runing a 11.57 @122. I compared the log against the run with the new setup and this is what it look like....
    42-120mph 8.081 sec. Fayetteville dragstrip
    42-120mph 7.550 sec. back-roads holding the steering wheel with the grip of death....
    Picked up over a 1/2 sec or .531sec. !!!
    This is just with a ruff tune with too much fuel in it....very impressive...
  2. #42
    Feb 2009
    Hope Mills, NC
    Quote Originally Posted by GXPaycheck View Post
    Trying.....not......to........give......in........ ...
    Resistance is futile.....
  3. #43
    Feb 2009
    Hope Mills, NC
    Default Pump....
    Quote Originally Posted by thebeast View Post
    Awesome job Rick. If you are pushing the stock pump this far, then I should be fine where I'm at. I just think my zr1 injectors are too small(93%) idc at wot
    Every pump is different. Blue-Meyhem's pump wouldn't hold up on his with a stock cam....so you just have to drive, tune, and judge it from there. If the fuel pump lays over hot, then you need a pump. Brains would be ok cold but after a few hard drive it would lay over and would fall on its face above 5000rpm.
  4. #44
    Feb 2009
    Hope Mills, NC
    Quote Originally Posted by locrzn#92 View Post
    Pretty cool, what do you think of the cog drive?
    Very nice! But I think one should upgrade to a LS7 MAF w/4" and get the porting done first, whether it be the throttle body or throttle body and manifold. Then see where you are with boost and pulley it from there. I may be dropping down to a 3.1 pulley to get the boost a little more realistic. It may be ok with short bursts here-and-there but a road course....?
  5. #45
    clark, mo
    So, the 3.3 with cog will create more boost then the 3.1, correct?
  6. #46
    VIP Member blue-mayhem's Avatar
    Huntsville, Tx
    No a 3.3 with a rear cog will be less boost.. The smaller the pulley is in the front will turn the blower faster which makes more boost. Doug was running a 2.8 front pulley with a overdriven cog. That's why Rick is going to a 3.1 pulley to lower the boost to about 10-11ish psi.
  7. #47
    Huntsville, Tx
    Quote Originally Posted by G8-4-Speed View Post
    ok....WOW....
    got a bit too much power out of it......14.8 psi....
    LS7 4" MAF must have been worth a few psi....
    Picked up a little over 4+psi. It is a monster.....
    I am surprise to be able to push it with still running the stock pump. 60 lb injectors were at 88%....Going to have to try a 3.1 pulley....
    Very nice Rick... Tame that Beast!!!
  8. #48
    Apex, NC
    Quote Originally Posted by blue-mayhem View Post
    Glad you still had the pulley Brian; I'll buy it back from you if it works and you want to part with it!
  9. #49
    Huntsville, Tx
    Quote Originally Posted by Doug Hilliard View Post
    Yeah that should work... You can just give Rick the money for it if that works for you... I'm going to chance my exhaust to a full 3" pretty soon and I'll need him to weld it up so It will all work out. I sure hope your fuel pump keeps hanging in there.
  10. #50
    Feb 2009
    Hope Mills, NC
    Update...I got the boost down to 13.3-5 without changing the pulley. I had adjusted the bypass throttle blade set-screw since the blade was open a bit much for my taste, so I adjusted it back. IATs are a little better and still pulls like a beast!
