Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 85
Thread: Checking,Filling,Changing ATF
  1. #41
    VIP Member pokey's Avatar
    Default ...well that was fun
    I put back in the quart + I let drain out yesterday. Started over and this time made sure the transmission was in the correct temp range before I ran it through the gears and then checked immediately. I'm thinking this is the proper procedure from my experience last night and the info posted previously. Mine was maybe 1/2 quart low but nothing which would affect operation.
    What a pain in the ass! I'm not sure if the weekend spent was worth the piece of mind, and my girlfriend was concerned I was with a "Tranny" for hours!
    Good though to get under the car and have a look around, plus changed my oil/filter.
    To fill I used about 7ft of 1/2" OD 3/8" ID nylon tubing run about where the dip stick is supposed to be, worked great...the easiest part of the whole process.
  2. #42
    Senior Member syP's Avatar
    Jan 2009
    Wheaton, Illinois
    so let me get this straight...
    if the fluid level is fine.. and i take out that drain plug... it shouldnt leak? Almost like a empty cup at the bottom of a drained bathtub ? Once the water level reaches the top of the cup, it will pour into the cup (ie, onto the ground )
    White Hot 2008 Pontiac G8 GT 6.0L
    Daily Driver.
    1993 Ford Taurus SHO MTX.
    Garage Queen.
    3.2L Swap, Full Suspension, 13" Cobra Brakes.
    -Gone: 2008 Liquid Red G8 GT, 12.44 @ 107 w/ 1.66'
  3. #43
    Check the beginning of this thread for the procedure.
    DO NOT pull the 'plug' when the car is off, Trans sump not warmed to proper degrees or before shift the transmission through each gear for a few seconds. Else you will loose some fluid.
    The example you described above with the cup is essentially how this works, but you have to follow the procedure posted by Charlie before removing the check 'plug'.
    I only did it to diagnose (rule out the transmission) as a source of a different issue I'm having with a vibration.
  4. #44
    Jan 2009
    Wheaton, Illinois
    awesome... thanks alot.
    makes me wanna install my own TC now
    Daily Driver.
    Garage Queen.
  5. #45
    pissing'n wind = wet face stryker g8gt's Avatar
    G'ville, SC
    make sure your tranny temp is in range......very important.....Do not skip on the steps
    Don't ask me how I know.....
    V8 Muscle
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
  6. #46
    Jan 2009
    Emmett, Id.
    On a side note, which one of the two lines coming out of the trans is the return line, the upper or lower, I want to install a aux. cooler, thanks.
    Ron
    Ron Neisler, Emmett,Id. 1987 T/R 11.69@117
    09 G8 GT, 13.61@103.98 with a 2.18 60ft.
  7. #47
    STL
    did this today in the garage with 2 jack stands a jack and 2 ramps..
    the did my Rear plate seal and rear main so i wanted to double check the trans level..
    put the back on ramps and leveled the car the best i could i did the whole thing and let it run till it stopped dripping..
    Then grabed my Mighty Vac and put a little in started flowing out and started to drip, then i stopped.
    i think the dealer may have over filled it maybe half a quart..
  8. #48
    Jan 2009
    Emmett, Id.
    I would have left that 1/2 qt. in. JMO.
    Ron
  9. #49
    In the middle of NC
    I am glad I have a manual! That would be a pain in the ass!
    Good write up.
    - John Henry Boetcker
  10. #50
    VIP Member BW G8GT's Avatar
    Inglewood, CA
    Quote Originally Posted by 99-LS1-SS View Post
    The procedure to check and service M6 is different than A6?
