Does the 2300 use the same manifold? Like can I replace with a 2300
I believe so. The rotor cases are different of course. The upper manifold will be different because of the mounting of the rotor case, but the lower manifold is likely the same.
I ported the lower manifold and opened up the snout to a 102 inlet. It also has a phenolic spacer plate between the upper and lower manifolds
did you guys change the oil? if so how did you do it
Not yet
