Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: First STOCK GXP in the 12's
  1. #31
    1GXP4ME by any chance what was your launch rpm's at and did you sport manual shift the car or did you just put it in drive and let her rip.
  2. #32
    Senior Member 1GXP4ME's Avatar
    Pasadena, MD
    I launched @ about 1500 just rolling into throttle, as far as shifting it was just left in sport mode
    09 PBM G8 GXP A6
    Official stock GXP record holder 12.81@109.64
    Mods as of 5/22/11 Vararam CAI, Corsa Catback, Kooks 1 7/8 long tubes, Corsa catted connection pipes, and RPM tune.
    Power 403/397
    Modded time 12.12@115.05 w/ 1.84 60ft on stock tires 10/28/11
    Modded time 12.10@117.27 w/ 1.86 60ft DR 5/3/2013
  3. #33
    Addicted Member bracketracer's Avatar
    Dane, WI
    This is going to bring an old thread back to life, but I think it will be helpful. I have been curious what tires your GXP has 1GXP4ME, are they Potenzas or RS-As? I also wonder if you know what the Density Altitude was when you made your record passes? You made some awesome runs, congrats! Are you waiting for cool fall air to see if you can improve on them?
    Joe Morgan, G8 GXP Registry Organizer, G.O.N.E. Organizer
    2009.5 G8 GXP WH 6M onyx/red no roof 12.921 @ 108.89 BONE STOCK! (then), (now) 12.344 @ 110.92 with 1.688 60' at 766' DA, PB with new cam & tune 12.191 @ 112.35, 2:59 Second Lap Time Road America (Goodyear RS-As & Hawk HP Plus pads with stock rotors), 143.1298 mph NoFlyZoneMidwest 2017 1/2 mile into 20 mph headwind. RACECAR NOW RETIRED. All of these are final PBs.
    VCM OTR CAI, HSRK, Heater Hose Relocate, custom street/dyno tune by oldskoolgp, Comp Cams 224/228 .581"/.588" 112 LSA cam, LS7 lifters, PAC 1219x springs, Monster LT1S (C7 Corvette) Clutch kit, Katech C6 Hvy Dty Master & Slave Cylinders, Camaro 1LE Diff with 3.91 gears, Kooks LTHs, Solo Hi-Flo Cats & Connector Pipes, Solo Mach Balanced Catback, BMR Toe Rods, Trailing Arms, Cradle & Diff Poly Bushings, 2017 Chevy SS front & rear Brembo calipers and rotors.
  4. #34
    Mad Apprentice Tuner edmanet's Avatar
    MD
    Quote Originally Posted by bracketracer View Post
    I bet he is. I know I am. I owe Jay a run down the 1/4 in my car.
    11.350 @ 118.66 / 1.57 60ft [300 DA]
    RPM tune, PatG cam, FAST 102, L92 heads ported by Greg Good, Kooks 1 7/8 headers,
    RotoFab 102mm CAI, LS3 maf, UDP, JBA wires, Meziere water pump, SJM linelock,
    Circle D 3600, 3.27 diff with Truetrac, GForce HD axles, Pedders bushings, Spohn trailing arms,
    Camaro rims on the street & CCWs at the track....... SOLD
    Looking for a 00-02 Camaro SS with A4
  5. #35
    Addicted Member OLD_GOAT's Avatar
    Quote Originally Posted by 1GXP4ME View Post
    I have done the exact same thing, but have only launched at 750-1000, and at about 100' from the end of the run, the car goes into 4th and I lose time.
    http://forum.grrrr8.net/showpost.php...96&postcount=1
    Did you do the 'hold in 3rd' trick on leave it purely in 4th? Even when I left mine in 3rd, I hit the rev. limiter and lost time and mph.
    Your car is bone stock with the stock tune?
    2013 Deep Impact Blue Mustang GT, automatic. None premium. Steeda lower control arms, GT 500 axle backs, BAMA tune, Nitto 275/40/17 NT05R drag radials, Airaid CAI.............12.13 @ 115.33......1.891...... 4/19/13 Royal Purple
  6. #36
    Pasadena, MD
    Yes car is completly stock w/ Potenzas, The DA was between 700-800 ft, I am waiting for another cool day to shoot for some 12.60's w/ some negative DA. OLD_GOAT you cant hold 3rd in the GXP due to the 3.27 gear, unless you put on a taller tire.
    09 PBM G8 GXP A6
    Power 403/397
  7. #37
    Dane, WI
    Thanks for the update! You have definitely set the bar very high for the rest of us to shoot for. I have been very curious what tires you were running and in what DA. That is really good air. I won't see that up here in WI until at least September or October. I plan to keep my GXP out as long as I can and try to get one of those "great air with a tail wind days" to hit the track in fall. Since I am running RS-As, and a manual transmission, I'm doubtful that I will surpass your numbers, but I'm sure as hell gonna try. Thanks for giving the rest of us something to strive for, and great run!
  8. #38
    MD
    Jay I cammed, geared, and re-stalled......looking for that negative DA also.
    Maybe some 11.50s........
  9. #39
    Pasadena, MD
    Cool you changed cams? Did you tighten the converter?
    09 PBM G8 GXP A6
    Power 403/397
  10. #40
    Feb 2009
    Oxford,Pa
    ???? I thought he was there for stall and 3.27 only hmm but 2600 or 2800 I forget what he said but it's a single disc this go around
