Results 21 to 30 of 46
Thread: P0633 theft deterent error on Replaced ECM? car wont crank!!
  1. #21
    Beyond Help gr8lover's Avatar
    SE Michigan
    Quote Originally Posted by GTPprix View Post
    Send it to me I'll check it out I'm guessing they didnt program ANYTHING into it so its blank; I can program it for you.
    Chris that would be awesome.... I will send you a PM...... usually up in your area 2-3 times per week....
  2. #22
    SE Michigan
    still no luck...... keylock symbol is gone now after the tries.... but still no start.... is Keylock symbol supposed to always be there before you start?..... is it still on your dask or does it dissapear after a security learn process???
  3. #23
    I know from Remote Start installations that usually that key will show up if you manage to get the vehicle to crank without the chipped key in the cylinder. Usually the car would crank over and maybe even start, but then die when the ECM? realizes that they correct chipped key isn't in range of the key cylinder. I know you didn't change keys or cylinders, but changing the ECM may have something to do with it. Chances are you'd need to reprogram the keys to the ECM/BCM before it would respond.
  4. #24
    Vendors
    It's because the unit is completely blank more than likely. Like I said ship it up here with your VIN I'll program it and send it back.
  5. #25
    This thing runnin yet!? :-) I'm going to national meet this year!
  6. #26
    SE Michigan
    No luck yet.... tried a bunch more things but nothing.... starter clicks but doesnt rotate and the fuel system relays dont go on...... so like others have said... it is something with the ECM and/other modules causing the issue..... I am hoping Chris White can set me up.... Hoping to drop off ECM on Wed to Chris but not sure if he will be around to get it from me.... hopefully!!! Everything is done and ready to be kicked off tracks...
  7. #27
    SE Michigan
    Chris, it was received at your address on Wed morning. It looks like you work on Sat/sun. I hope you can get too it this weekend. If you are too busy or will not be able to get to it... please let me know ASAP so I can come pick it up at your address ASAP.... I know you are quite busy so if you cannot get to it due to backlog, etc... I just need to know so I can make other plans.. My issue is I need to get this resolved so I can clear room at tuner asap. Thanks for your help on this... let me know when you expect to have it ready and if I can pick up at romeo plank (ups) or what.... but thanks again!!!!
  8. #28
    .............?! This week?
  9. #29
    Banned
    Jan 2009
    Chicagoland
    I'll bet the ECM is bad or blank like Chris said. If the security relearn doesn't work that has to be the problem.
  10. #30
    I dont know if I will ever find out.... I dropped ECM off to Chris's Address on Wed after he said ship it to him... I emailed his webiste 2-3 times asking to talk to him, and also PM'd him on this site... but no response at all..... dont even know if he got the ECM.....
    its not like it wasnt clear that I was in a hurry to get this ECM fixed.... but who know when I will get contacted.... maybe today hopefully.... but since I didnt hear from him on Wed/thurs/ fri/ sat.... I went ahead and had to buy another ECM from Vector cause I just cant wait anylonger.... I somehow believed that it would be a quick turnaround.. but I guess I was wrong..
    hopefully I hear from him soon..... I am guessing he is out of the country and not checking emails otherwise I am sure I would have heard from him by now..
    Sucks! :-(
    Melt away that frustration and get that baby fired up!!!!!!
    Edit: Does no one on the site have his contact #?
