Results 21 to 30 of 49
Thread: Hard time with SPOHN lowerend control arm
  1. #21
    VIP Member pokey's Avatar
    The passenger side is easy, the drivers side you have to lower the rear frame.
    The car needs to be aligned as well. I highly recommend the Pedders alignment bolt kit for the rear. Rob can get that for you as well.
    What is the advantage of the alignment bolt kit? Where should we go for an alignment? Can most shops complete an accurate 4 wheel alignment on the G8? I'm starting to think maybe I shouldn't complete this mod for a daily driver??
    Thanks for the insight
  2. #22
    Sugar Land Texas
    Quote Originally Posted by pokey View Post
    The factory alignment bolts SUCK! They do not hold. The Pedders have a much better/thcker washer and use double nut for locking them in place.
    Any good alignment shop can perform the alignment.
  3. #23
    Oct 2009
    Chicago IL
    I think I will just wait till I get the car on a lift then do it, what’s the point/advantage of the subframe bushing that you recommend of putting on ?
    Torque@ 349 HP@ 341
  4. #24
    Sugar Land Texas
    Quote Originally Posted by kade7236 View Post
    The factory frame bushings have a lot of sloppiness in them and the inserts tighten up the back of the car.
  5. #25
    Clarks Summit, Pa.
    The rear sub-frame is attached to the car with 4 bolts. Those bolts go through big rubber bushings. Those bushings have huge voids in them. GM/Holden designed them that way to transmit less road noise to the chassis of the car.
    They work as designed, but they allow the rear sub-frame to move around quite a bit. You can feel it if you whip the cvar hard into a corner under power. It also moves around a lot while launching the car. the sub-frame actually moves forward before the car does, wasting energy.
    The Pedders and the BMR bushings fill those voids with a poly insert. The sub-frame moves a lot less.
    Plastic Cuttin' Bad Ass!
  6. #26
    Oct 2009
    Chicago IL
    Thank you,
    also
    I was thinking about the Alignment Kit, but there is no way in hell I’m paying almost 300$ for some stupid bolts !!!!
    This is FU**ING crazy even if they were made out of solid gold that would not justify the price
    Torque@ 349 HP@ 341
  7. #27
    Sugar Land Texas
    Thank you,
    also
    The rear bolt kit is $200 I believe. Well worth it, but it is high.
    It is the price you pay for driving a car that is unique.
  8. #28
    Oct 2009
    Chicago IL
    Torque@ 349 HP@ 341
  9. #29
    I was thinking the same on the cost of the bolts. I'd like to give Pedders some of my money but those bolts are a little rich for my blood at this time.
    BlackBerry8330/4.5.0.77 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105
  10. #30
    Oct 2009
    Chicago IL
    for that price they should knock on my door say hello sir cook me diner and wash my car the put them self on the car!!! o and a
    Torque@ 349 HP@ 341
