Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: PIP4765: Engine Misfire And No Compression Due To Piston Damage
  1. #21
    Jun 2013
    P0420 code keep popping up, does anyone know which sensor to change, is it the driver or passenger
  2. #22
    Jun 2013
    I have a p0420 code, which sensor do I replace, the one on the driver or passenger side, I also need to know where the stability control module is located
  3. #23
    Jun 2013
    No I did not, would you know where the stability control module is located
  4. #24
    SoCAL
    Perhaps you should try creating a new thread instead of piggy backing on a (more than likely) unrelated thread.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    **RIP Shaun Finley**
    FUCK CANCER
    **RIP Charlie**
    '16 2SS NFG Camaro M6 NPP Mag
  5. #25
    Quote Originally Posted by WickedMom View Post
    X2, am having a hard time following this!
