That's a smart plan, GM developed the parts ,and the dyno numbers they state are usually on the money.
Well I just kept reading 480/475 and it was only 12 cu in more and with manifolds. I crossed all parts to find out every difference and found the intake valves are hollow(doing them too) and compression was a little bit more(doing that too) Other then that the engines power wise should be close. Now add ARH and all my bolt ons and I cant see not getting over 500 at the flywheel.
Guess this means we'll have to wait a little longer to see ITBFAST in action
2009 Jeep Grand Cherokee SRT8 Fully Loaded, tinted, stock for now
Gone: 2008 G8 GT. Premium Package. 30%tint
Vararam, HSRK, Vector ECM/TCM Tune, PM-Fl Axle Back
R.I.P. Charlie
I wish I had the camera rolling for you Rick when I did a 150ft tire smokin burnout when I got the headers done. No converter either!
Oh sure, tease us why don't ya. BTW, Love all the crazy smilies.
R.I.P. Charlie
You can thank that lunatic Chris (4gasem) for them. I told him 200 minimum and he lost his mind! lol
Hey Charlie, I'm sure you have see this, but if you haven't take a look at this.
It is an LS2 crate motor (same bore and stroke as an L76) with L92/L76 heads and the hot cam, same as the one in the LS376/480.
It makes peaks of 467hp and 440tq. It is on page 107 of the 2008 GM performance parts catalog. If you don't have one it can be viewed in a PDF format at http://www.gmperformanceparts.com . if you go into the "dyno" and "build" the LS2 with the L92/L76 heads and hot cam you can then print this sheet that shows the dyno results. Being that they are starting with the crate motor Iassume they are using manifolds.
http://www.gmperformanceparts.com/_r...3_10214664.pdf
sorry for the long reply, but I thought it interesting. swap a cam and delet DOD and it should be the same damn thing.
I have all that info and it is what I used to make my final decision. I have never been much on guessing or experimenting on Daily driver projects. Pick a combo that is proven, kick it up a notch(ported intake, T-body and some ARH 1 7/8 long tubes) and you have an awesome street car that is a sleeper if the right muffs are used. I cant wait! Good to see you again Cliffy!
Since we're talking flywheel horsepower today here's a chart from desktop dyno.
*Note heads milled for 10.9 comp
Red line is a baby 220/220 .581/.581 on 112
Yellow is a 224/230 .581/.590 on 112
(You'd prolly use a 114 on an auto)
Predictions aren't far off as an 06 GTO with the 224/230 on 114 but with stock L92 heads (10.4 comp) put down 450rwhp.
