Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 83
Thread: CTS-V / Vaporworx Controller install
  1. #21
    VIP Member blue-mayhem's Avatar
    Huntsville, Tx
    Make sure you check your Noise Filter on the controller out. Pretty sure that Carl has sent everyone a email that has bought a controller from him, but if you don't know what I'm talking about I can forward the email or just contact him about the noise filter. Not a big deal, but my filter was one of the bad ones. He is sending me a new one ASAP with no charge. By the way the fuel system is still working great!!!
  2. #22
    OK, I have my hole cut, and some stuff pre-assembled. Making sure I understand how everything is connected before I pull the stock pump out. One remaining question. The blue wire needs to go to an IGN+ source. I assume one in the trunk? Where is a good place to hook this up?
  3. #23
    Huntsville, Tx
    The blue wire will connect to your OEM + fuel pump wire (Grey 12 gauge wire). That is the turn on source for the controller and you will hook the controller up straight to your battery. Let me know if you don't understand... I drew up a wiring diagram somewhere around here.
  4. #24
    Quote Originally Posted by blue-mayhem View Post
    OK, got it. I was over thinking or is that under thinking it. Straightforward then.
  5. #25
    Huntsville, Tx
    I did the same thing!!! Yeah pretty straight forward.
  6. #26
    OK, today I worked on getting this installed. Talk about stuffing 10 pounds into a 5 pound bag. Tough to get everything connected on the hat and get it into the proper position. I will update this thread with some things I discovered today to hopefully help the next guy out, but first I have an issue. No fuel pressure First thing that comes to mind is when it was not working at first, I realized that I had forgot to put the fuse in the little fuse holder When I went to put the fuse in it shot a spark. Could this have done something? Is there another fuse to check? I can run through the wiring tomorrow night and make sure nothing is loose or wrong. Any suggested steps for debugging this?
    Ran out of time tonight and zonked after working in the hot garage all afternoon/evening. Too tired to think about much now, so I will concentrate on this extremely stiff drink until I go to bed.
  7. #27
    Pm'd you
  8. #28
    Huntsville, Tx
    I must have over looked this... Did you figure out what was wrong? Let me know if you still need help.
  9. #29
    Figured out that I am an idiot, and am waiting on parts to fix the idiocy. Also working to help the next idiot so they do not have the same issue.
  10. #30
    Aug 2010
    I'm getting ready to install the CTSv pump into my G8, (will order tomorrow) but i'm wondering if you guys did your back seat pump cut-out access hole with the tank removed, or just followed what seems to be an outline...??
    I'll be running the 2300 maggie with ls9 injectors. Also have the livernoise cam and LS# head package.....any suggestions would be help full...thanks
    Also, long shot, but does anybody have a canned tune I could use..I have HP tuners, but never really learned how to tune myself....just need a tune (or advice) how to get the ls9 injectors to fire with the new ctsv pump...just enough for me to get to my tuner....
