If I remember correctly, Pete had trouble with his too.
I'm trying to decide now. I was able to get the nipple piece out of the connector now that I had the room to use the disconnect tool. So it seems like it will still hold fine. But if it ever had to come back off in the future, do I stand a chance of ever getting it off with the tabs broken off. What can I use to repair it with?
Maybe just replace the line section?
Mine was a reeeeal pain.
Sent from my LG-H871 using Tapatalk
I've ordered the tool mentioned above (en46843), just so I'll have it in the future. But I don't think it will work on the connector with the tabs broken off. So I also got the Dorman repair kit below and a compression union. The Dorman repair fitting has a clip that is easy enough to remove without special tools. I've tested it with success on the broken nipple/post.
https://www.amazon.com/gp/aw/d/B000C...op_mb_pd_title
If I used the barb, I'd heat it and put a hose clamp or zip tie on it, though neither was supplied. I'm going to use a compression union instead. I think they are more secure, and easier to uncouple if needed.
