Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Autodim Mirror install
  1. #21
    Clayton, NC
    My Blendmount works fine with the stock mirror. They did send me a longer bracket for my SS though.
    RIP Charlie, The GRRRR8 One
    [SIZE="2"][COLOR="Red"]
  2. #22
    Mar 2015
    $10 shipped on ebay. Thank you for the part number. Looks like they use the same mirror on a WIDE variety of cars. Mine supposedly came out of an 03 impala.
  3. #23
    Bothell, WA
    Quote Originally Posted by Monty View Post
    It's a no problem install. 5 minutes out of your life.
    Here is my write up on how to do it.
    http://forum.grrrr8.net/showthread.p...dimming+mirror
    2009.1 Pontiac G8 GT
  4. #24
    Senior Member bowtiefan's Avatar
    Jan 2009
    Cleveland, OH
    Are there any known mirror model numbers where everything will work including temp?
  5. #25
    Dec 2014
    the last time i had my blendmount plugged into the trailblazer mirror i noticed my ValentineOne was getting really hot. can anyone confirm which holes the blendmount prongs go into?
    2002 Camaro Z28 - far from stock
    2009 G8 GT SRM #1 - Sold
    2009 G8 GT SRM #2 - Sold
    2015 Chevy SS PBM - the new new!
  6. #26
    Mar 2015
    Quote Originally Posted by bowtiefan View Post
    DCA883459596 is the part number I used.
  7. #27
    Mar 2015
    Quote Originally Posted by Wagonbacker9 View Post
    So the 03 impala mirror doesn't include the compass.. didn't look closely enough before buying... $10 wasted, oh well.
    From what I've seen, all of the mirrors (various options) are GNTX-261s.
    The part for the mirror with temp is 015607, but it looks to me like this part was used on a wide variety of mirrors. Some with map lights, temp, compass, onstar.. I even found a tan one from an acura that uses the same part number.
    Short version... you almost have to go off of a picture.
    Here is a pinout for the configuration:
    Black=Pin #8=Ground
    LT Green w/Black tracer=Pin #6=Ambient Air Temp Sensor Signal
    Gray= Pin#7=Ground for Ambient Air Temp Sensor
    Yellow=Pin#13=Switched 12v
    LT Green=Pin #9=Backup Lamps Supply Voltage
    Temp sensor with bracket GM PART # 15047946 $13.21
    Temp sensor by itself GM PART # 25775833 $3.27
    Temp Sensor Part number RockAuto #25775833 $3.35 (cheaper shipping)
    The OE harness is stupid expensive so if the pigtail doesn't come with your sensor, nothing stopping you from using just a 2 wire weatherpack.
  8. #28
    Has anyone looked into wiring in the "Backup Lamps Supply Voltage?"
    I did this on my Grand Prix GXP so that the mirror undims as you put the vehicle in reverse.
  9. #29
    Member BAMAGXP's Avatar
    Sep 2010
    Or you can do what I did. Almost as easy and it dims. https://youtu.be/-MXq_zdJnE0
    2009.5 G8 GXP SRM M6 (1 of 61), (1465 build of 1829 total GXP's)
    a.k.a. "Michele"
    GO: Kooks MID's Headers, RotoFab. Corsa Cat Back Exhaust, Texas Speed Stage 2 Cam. FAST 102
    RIDE: Pedders GSR's with the Lowering Spring, BMR Cradle and Radius Rod Bushings, Pedders Sways
  10. #30
    Quote Originally Posted by GXP25 View Post
    Forgot to update this: Our harnesses are already pre-wired with the "Backup Lamps Supply Voltage" wire at pin 9.
    2009 LR G8 GXP - M6, Roof, Onyx/Red Interior
