3M windows enhance the performance of your windows. They are used not just for automotive purposes but also for commercial and residential purposes too. Even for laptops, TVs, cell phones and more. When you happen to spend more time inside the vehicle as a passenger or a driver, 3M windows ensures protection from excessive heat, increases privacy, protection from UV, faded interiors, glare or security of your vehicle. They not only increase the comfort but also the appearance of your vehicle. Turn to 3M Authorized Dealer Installers to help you find the right solution. If I am not wrong 3M Automotive Window Film Crystalline Series rejects more heat than darker films without changing the appearance of your vehicle (its a multi layer optical film combining 200 layers of nano-technology in a film,so thin).
Now, Cellular Vinyl has many advantages being the most installer-friendly and durable building materials in the market. Check this article for its advantages http://www.landmarkquality.com/blog/...cellular-vinyl . They are said to be Maintenance Free, recyclable.
I'm thinking of using plastidip since it is easy to apply.
