Like Paul said. Be easy with the sticker. You can't get them separate, but Paul does sell the Holden logo if you don't mind that.
Oh so only the better one is available
Hope I don't need these instructions but very happy to have a place I can find all the help I need, thanks CP!
2009.1 SBM GT (02/2014)
LS3 376 swap
EPS Cam 224/230 .629/.629 114 +4
GXP front fascia and rear diffuser
Pat G tuned
VMR 19x8.5 245/40ZR19 Nitto MOTIVO fronts
VMR 19x9.5 275/35R19 Nitto MOTIVO rears
DBA + Hawk Brakes
Kooks 1 7/8
SOLO Mach Unbalanced w/ SLP tips
Rotofab CAI
Ported Intake/TB
Billet Catch Can
LS7 MAF
TRS XB35 35w 6000k HIDs
TRS XB LED Fogs
Sharkfin Antenna
20% tint
2009.1 MGM GT (10/2012) SOLD!
rotofab
Pat G tune
solo axlebacks
camaro 20's
nitto 555's
I took mine apart and found more than a loose screw. I replaced all the parts and took the old key blade and put it in the new parts. Super simple!!
Sent from my iDevice using data nodes and algorithms.
Repaired and old one side by side. The difference is amazing!
Dumb question chewy,the buttons plastic? Or fresh rubber compared to old?
Sent From: A Nuclear Plant
Rotofab
Kooks LT
Solo HFC
Solo Mach
Pedders Street II GSR kit
Livernois 1C Cam DOD Delete
Milled Heads
Ported Intake
Ported Throttle Body
Bolt ons dyno W/Pat G tune: 364/373
After:430/404
New button assembly! Just reused the PC board inside since it's programmed for the car.
Sent from my miniaturizer via tap dancing...
Seems this is a common occurrence, I have to order mine as well. I searched to get here but didn't see who you guys ordered the replacements and stickers. Just see names no company/link. I just see "Paul", which I'm guessing is "Crazy Paul". Thanks for the info thread though. Simple and effective write-up.
Edit- NVM found part number post and just searched web to find my second guess was correct with Pace.
Last edited by 2nice2slow; 01-27-2014 at 10:21 AM. Reason: Correcting Question, found Solution.
Yep, PM Greg for pricing and such. DO NOT use the website.
