Results 11 to 20 of 29
Thread: Timing Chains at 50k
    Looks like the layout for a roller coaster at Coney Island. Thanks for posting the picture. Is the tensioner that device that is to the right and up from the center of the front of the engine? The device with the "X" marked on it.
    Old Retiree in a Infiniti
    Current Car - Infiniti M37S
    Junior Member harleymonster1's Avatar
    Feb 2009
    East Coast Mecca
    Thanks to you all and i will be asking more indepth questions when returning to the dealer to have it serviced. The wacky thing is as of right now the check engine light is off and no issues have arised, according to my dealer as well as the folks at on-star the engine will operate at 100% with the system resetting itself and the cams are in sync. Listen, i am no machanic but i am not an idiot either i have to believe that once an issue comes to the fore-front that issue continues until rectified, yes or no. I change the oil every 3-5k depending on my travels, i am an aggressive drive but not a stunt driver and i service the vehicle according to dealer specs. The car is an 08, and the design of the chains ( all three of them running the double cams ) have been around for a couple years but new to the G8 in this model year. There have been a couple of similar posts on other sights but i will keep you LY7 guys up-dated........Have a great Holiday and b safe.
    GO BLUE.....BO KNOWS
    I would insist on getting the chains replaced. If the chains are stretched, the problem isn't going to go away, but your warranty will.
    Addicted Member Sephiroth's Avatar
    Dec 2010
    Suffolk, VA
    Quote Originally Posted by Panzer Leader View Post
    there are 3 independent chains. your assumption is correct, the individual bank tensioner for the right side is the one twoard the inside of the block, the one for the left side is the other one marked X on the outside of the block, and the middle chain at the bottom's tensioner is the one toward the top inside. Everything else are just guides.
    Ray is totally correct. My only concern is that GM will say, "When it breaks we will fix it". Which is why I asked will the chain breaking lead to other damage. It seems that most companies today would rather replace component modules than say individual pieces. I have not noticed any symptoms of this problem. But I don't run the car hard. So I have to ask, how do you drive? Also, what may cause premature stretching of the chain? Fast take offs? Continously hitting the passing gear? Also, are there better aftermarket timing chains and tensioners available? Of course the problem with installing these is the drivetrain warranty.
    MA
    Quote Originally Posted by Sephiroth View Post
    Eye spy 7 tensioners
    I don't think this is correct. I think most of what you think are tensioners are just smooth surfaces for the chain to run against in order to keep the room that it takes within reason. To be a tensioner, they'd each need to have some sort of spring setup that would apply pressure.
    Dec 2010
    Suffolk, VA
    Quote Originally Posted by dandragonrage View Post
    Quote Originally Posted by sephiroth
    3 tensioners, 4 guides.
    MA
    gotcha
  9. #19
    Dec 2010
    Suffolk, VA
    gotcha
    I get lazy with my typing without my coffee
  10. #20
    Senior Member 2QUIK4U's Avatar
    Chesterfield,Va
    If the chains are stretched to the point of causing a CEL they should be replaced under warranty no questions asked. I would take it in ASAP.
    09 Stryker Blue G8 GT 435/405 Full bolt-ons, TSP 229/236 Cam, 3200 stall, Camaro diff, tuned by Frost, Pedders Suspension
    02 SS #510 M6 440/400, 585/592 100 shot Sold
    98 Z28 M6 cam/boltons 395/377 Sold
    73 Z28 Neverending project Soon to have a 454LSX with twin-turbos
