Results 11 to 20 of 21
Thread: Fastest Stock Converter N/A pass RECORD.......
    Feb 2009
    Hope Mills, NC
    Here is the Spectre LS7 4" MAF tube part number for $30 -9705
    LS7 MAF Sensor card numbers-LS3/7 MAF card @$50-70
    AC Delco # 213-4222
    GM# 15865791
    Supercedes 213-3134 and GM# 12576410
    Boosted the intake will do even better....It just multiplies the gains...Intake and TB are $300 as a pair.
    ***This 4" and card will need a tune to run***** The MAF airflow table needs recalibrated for the larger tube.
    Feb 2009
    Hope Mills, NC
    Quote Originally Posted by DavesG8GT View Post
    Insane times Brent!! Congrats. Now Rick has me thinking of swapping cams, or at a bare minimum doing the 90 mm MAF.
    The intake lobe and centerline are good on your cam but your exhaust opens way too soon and bleeds off too much torque which is hurting your et.
    clark, mo
    Pretty impressive, the 60' is keeping you from 11's and the whole package makes this car work like crazy.
    Beyond Help DavesG8GT's Avatar
    Jan 2010
    Birmingham AL
    Quote Originally Posted by G8-4-Speed View Post
    AC Delco # 213-4222
    GM# 15865791
    Thanks Rick. Going to get this on the way next week and Pat G can modify my MAF tables.
    Also, when you can please reply to my email with exact cam specs you'd suggest and where to buy from.
    New (cheap monthly payment car, lol): '12 Candy Apple Red Mustang GT 5.0 6MT, stock for the time being
    **SOLD **
    White Hot '09 G8 GT, Pat G tune, Pat G cam (.634"/.608", 223/230, 112 + 2), G8-4-Speed ported & milled heads, "ram air" intake, & ported TB; Reckart 90mm MAF/LS7 card, HSRK, DT headers, Rotofab, Magnaflow CB, H & R springs, stock gears & stock stall, 11.865 @ 120.32 mph, 1.941 sec 60'
    Beyond Help ULTRA Z's Avatar
    Philadelphia, MS
    If you have the stock converter restalled does that ocunt as still a stock converter Just wondering
    2009 SBM G8 GT
    2007 Suzuki GSX-R 1000
    Feb 2009
    Hope Mills, NC
    Quote Originally Posted by ULTRA Z View Post
    Sounds pretty sneaky to me, I like it! It doesn't take much stall to make a big difference. 500 extra rpm really helps get rid of that lazy feeling off the line.
    Dave, let me get going on these intakes today and I'll try to get you an e-mail tonight on the cam.
    Philadelphia, MS
    There is a guy will restall a stock converter for like $200-$300
    2009 SBM G8 GT
    Philadelphia, MS
    A friend of mine with a cammed maggie 2010 camaro SS had his restalled by this guy and goes 1.5x short times granted he makes stupid torque of the line
    2009 SBM G8 GT
  9. #19
    Feb 2009
    Hope Mills, NC
    I believe it. Dougs is an animal is second anywhere on the street. I bet he would cut a easy low 1.60 with the stock stall and gears. For street use it doesn't take much stall to make it come alive. 2200-2600 is plenty!
  10. #20
    Senior Member blkscooby's Avatar
    Aug 2010
    Gilbert, AZ
    Wow, you picked up 25 MPH in the back half. Heads and intake are breathing well.
    Can't wait to run mine on 10/19. Hope for a cool night here in AZ.
    NEW 2009 PSM GT- Vararam/ RCR 219/227 cam/ Kooks 1 7/8" LT/ 3" exhaust/ 3200 Yank/ 3.45 gears/ HSW Nitrous/ HPT self tuned
    SOLD 2008 Liquid Red G8 GT / 20" MS Camaro Wheels / Homemade intake / HPT self-tune / GXP Front and Rear/ 35% Tint / E85/ 160* stat /Cat delete pipes/ Dynomax ST axlebacks / Xpipe / Mid-muff delete / 219/233 .553/.539" Thumpr cam / 7.425" Comp Cams pushrods / LS9 springs
