Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Anyone dealt with Rev Hard in the Quad City area
    Cool! I'm jealous! I'd love to mod mine, but I need dead nuts reliability and well it IS a lease... lol
    Chris
    Jan 2010
    Iowa
    Careful on Rev Hard, apparently their name is what they like to do to customers cars. A buddy of mine when there to get his supercharged big block camaro's carb tuned and ended up having to spend about 4K to fix his motor after they bent some valves in the heads while tuning on the dyno.
    Jun 2012
    Quote Originally Posted by gixxer92 View Post
    This is an absolute false rumor. We have never harmed a single engine on the dyno wether it be ford mopar chevy import, we have however hurts some transmisions due to weak u-joints, the big block 69 camaro came to us in pieces we pulled the motor sent it to the original engine builder we then put the motor back into the car and dyno tuned it. The customer was extremely happy, we even had it in the 29th annual Rod And Custom car show. we do tons of ls stuff I own a c5 corvette pushing 850 whp, we have turbo charged and superchaged many ls motors with great success we have done penty of internal egine work on ls moors too cam installs springs lifters etc. if it can be done we have done it.
    if you would like to see some of the stuff we have done check the links below.
    http://www.streetfire.net/videos/sea...x?t=revhardinc
    or
    http://www.youtube.com/results?searc....0.34UXDWarXnM
    just want the record strait saw this and had to correct the false rumor.
    Thanks
    Trent
    Rev Hard Inc
    any questions give me a call 309-788-3966 or toll free 1-877 RHI-DYNO
    Mar 2022
    Just to set the record straight as a ruler, my name is Marc Lundgren from Cedar Rapids Ia and it was my motor, a Procharged 454 BBC, in my 1967 Camaro that was destroyed by revhardinc back in 2006. There was only an occasional slight hesitation on the throttle while cruising that I wanted fixed. Other than that the motor was a monster and ran great. A week later after bringing my car to RevHard I picked my car up. No dyno run sheets, no nothing. The motor would barely run. I took it to my engine builder (Sperry Engines in Cedar Rapids Ia). The motor had 3 burnt pistons, scored cylinder walls, a cylinder with 60 psi compression, a cracked head by a water passage, a carb that was jetted down to the point of not being functional on the motor because it was so lean, fuel was leaking from the primary and secondary bowl gaskets and the gasket on the back of the water pump was blown out and leaking coolant. Since there was no dyno pull spec sheets on the motor my only conclusion is that they took my car out and beat the shit out of it. Trent, you are a liar.
