Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Aftermarket cam with stock intake question
    Quote Originally Posted by gr8g8 View Post
    Stock air intake will definitely leave power on the table when you go with an aftermarket cam. I'd say 15-20 rwhp.
    X2!!!
    OBX longtubes, varram, ported intake/tb nitrous outlet plate kit. 150 shot.
    ---UNLIMITED PERFORMANCE--- RICKIFAST TUNED!!!
    11.59-120 mph
    Junior Member MaxAvidy's Avatar
    Aug 2013
    Gaithersbrurg, MD
    Quote Originally Posted by ftlincolnls View Post
    X2!!!
    When you get the cam installed they'll tune the car for that intake, obviously, but yeah, depending on how aggressive your cam is you'll definitely be leaving power behind. You should be able to find a used varraram or rotofab on the site. I know I'm going to be selling both of mine here in a couple days.
    Roto-fab CAI, Kooks LTH & Catless xpipe, CTSV wheels/tires, Hawk Brake Pads, PatG Cam, Forged Pistons & Rods
    Member norton13's Avatar
    Jan 2013
    Toronto
    Not much. The only real gain on an intake is if you have a "ram air" and you need to tune that into effect to see a gain.
    I wouldn't worry about it. Just get a good filter for the stock one until you can get what you want.
    Also cheap headers are a waste of money if you ask me. I have the jba long tubes because they were on sale and they were as cheap as I wanted to go. Also I had the ability to clean them up. I took a die grinder to all the welds on the inside and collector. They are 409 ss and I painted and wrapped them but still have little rust. I wish I would have gotten better even tho I plan to turbo in the future and they were only temporary.
    Just my opinion tho.
    Good luck.
    I bought cheap headers but they are 304SS not 409SS. I did not want to pay 3 times the price for maybe 8 to 9 HP.
    VIP Member Ben2009GT's Avatar
    Puyallup,Washington
    Just do some research on this site, you will find what you need to do. There is over 7 yrs of information here someone has done what your asking about.
    515 rwhp - 416 Stroker - 2015
    2009 G8 GT PSP, 6.8L Stroker 416ci,CM 228/234 .629/.629 LSA112 +2 Cam,PRC LS3 255CC CNC Heads,Trunion Rocker Upgrade,RCR Intake,FTI Stall 3600-3800,Trans Cooler,B&M flex plate,3.27 Diff LSD,UDP,1 7/8 OBXR LT SS Headers/SS, 3",Borla Mufflers,VCM OTR CAI,LS7 MAF 100mm,Patrick G. ECM/TCM Tune,Koni Shocks/Struts Yellow,Eibach Pro Kit Springs,LCA's w/Whiteline bushings,BMR Sub Frame Connectors,Spohn Tunnel Brace,BMR Fr/Rr Sway Bars,Suspension/Diff Bushings,PMT Rear Trailing Arms/Toe Links,Brembo's Front Brakes,Russell Street Legal Brake Line Braided SS,V8 6.0 Side Badges,GXP Diffuser,G8 Door Sill Plate,Red Shift Knob,SS Rim's,BFGoodrich g-force 255/35/20-285/35/20
