Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 80
Thread: RDS tvs2300 plate anyone on here install one pics info?
    You can use LS2 style injectors if you do not want to use spacers. There are 4 thick washers that you put in between the front subframe and the body. 4 bolts to loosen and tighten. Ray will sell you the spacer (not the Ray on this board though). RDS = Rays Dumb Spacer. His shop is in Minnesota.I can't think of the name right now. I did not need a new belt.
    Friendswood, TX
    Okay - sent RDS Ray a note on the shim
    Friendswood, TX
    Bought the RDS spacer and injector spacers --- not the shims. Glad you brought this up for me to "check."
    Beyond Help Darkmanx's Avatar
    ft lauderdale fl
    So all I need is the injector spacers and the rds kit and I'm good to go?
    Quote Originally Posted by Darkmanx View Post
    He will supply the spacers too as long as you tell him what you are up to. Costs extra of course.
    Friendswood, TX
    Sent him a note - shims are only needed on 2300's
    I have the 1900 and needed the shims. You will be touching the cowl I think.
    Friendswood, TX
    Can't hurt to be "safe." ..... which shims do I need to buy to have on hand? size? part #?
  9. #19
    Friendswood, TX
    Thanks for the "coaching" on the spacers!!!
  10. #20
    I will measure when home.
