Results 11 to 20 of 24
Thread: Timing With Boost/Meth
    Apr 2010
    Ocala, FL
    I may eventually add meth for its cooling and cleaning properties. And of course pick up some safe power. For now, I'm relying on bap till I buy the squash pump.
    As to the op, I'm not too much of an expert when it comes to timing and meth. Rick Crawford will be the one to ask.
    2008 G8 GT
    Rick Crawford Tuned
    663/596 Rwhp rwtq for now....
    10.87 at 133 1.59 60ft
    Clear Lake, IA & Naples, FL
    Have you considered running a higher concentration of methanol... The Livernois guys and their EcoBoost engines are spraying 100% Methanol thru a single #10 nozzle (10GPH). Granted that engine is only 3.5 L and a twin turbo, the overall spray is higher per liter.
    The key to your timing is going to be your A/F ratio. I always tried to keep my EB Flex to about .82 Lambda or less which means an A/F ratio of 12 to one or less under WOT. I assume you are tuning with a Wide Band and are logging MAF, Knock, A/F, your manifold Charge Temp and how it changes over a normal WOT run. The cooler the charge, the less knock retard you will see. Also, spraying Methanol should allow you to raise boost. It's not just timing advance, but a combination of many things to get you the most power. With my Flex, I knocked off a 1/2 second off my ET and gained 5 mph when spraying 75% methanol.
    Confused, Dazed & Verklemp
    May 2011
    Texas
    100% is the way to go. I could run 14* more timing on meth + 93 vs 93 only. That much isn't really necessary for a street application though.
    2009 G8 GXP A6 - HMS Tune - Custom HMS 4" Intake 12.76 @ 109.6
    2013 5.0 Mustang M6 - 12.7 @ 112.01 SOLD
    2008 TBSS 3SS 2WD - 10.49 @ 129.38 SOLD
    Get Some hartigan85's Avatar
    Dec 2009
    Alamogordo, NM
    Just got home from work and have to say I didn't expect to have so many replies so fast. lol. I want to keep atleast a 50/50 mix becuase of the cooling properties of the water. I have the knock sensors set at the stock setting and still no knock. I have an activation light and low level light but I can't figure out how to set it up to pull timing if the meth runs out. I was tuned at 21* on 91 at 8psi before the meth and no knock, my AFR is set at 11.75 WOT. The great thing about the meth is my fuel is only spraying enough to get the afr to 12.5 and the meth spraying take it down to 11.75.
    I am gonna try and hit up the track again this weekend and then I can add more spark and see how it goes.
    Atmospheric Acquisition
    Pictures
    Apr 2010
    Ocala, FL
    Good luck.
    2008 G8 GT
    Rick Crawford Tuned
    clark, mo
    I hope to add meth this winter and I'll see if I can run that kind of timing.
    Feb 2009
    Hope Mills, NC
    Quote Originally Posted by hartigan85 View Post
    See if you can look at an old log before the methanol at what your IAT was. If you are getting a 20 degree IAT drop, then pull 10 degress at the higher IAT for no water/methanol. For the meth injection setup I did, I used straight methanol. Doesn't cool as much but I can pick up the power with less timing. We ran about the same as you with 16-17 degrees at 9-10 psi running 11.50's at 124. Was easier to keep the tune closer incase of a methanol failure. Only need to pull 4 degrees vs 10-12.
    May 2011
    Texas
    Quote Originally Posted by G8-4-Speed View Post
    ^^^^^^ I was gonna say the same thing. Or just don't go in boost when the low level light is on. I just can't justify spraying water through a TB, through an intake, through heads, and into the combustion chamber. Just can't....... To each their own.....
  9. #19
    Member ecmoney's Avatar
    Jun 2012
    west palm beach, FL
    ^^^^^^^^^ I was browsing through your sig, and your list of cars is f'ing phenomenal, hahaha
    http://i1134.photobucket.com/albums/...y/ef64e463.jpg
    2008 G8 GT
    BC coils
    kooks mids with HFC and corsa cat back
    VMR 19's
    239/243 .624/.624 on 114
    Yank 3200
    TVS 8lbs
  10. #20
    May 2011
    Texas
    Just a bunch of slow, that's all
    Lol, thanks for the conpliment.
