Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Track Times after RCR Little Lunati low lift
    Junior Member Edrooney's Avatar
    Apr 2017
    Lets hope these help
    Apr 2017
    I only paid $350 for the pair with brand new 275/40/17 nitto NT05 tires.
    Apr 2017
    Went back to the track with the drag pack. Same result best was a 12.96 at 112 with a 2.1 60 foot. No power down low. I did some experimenting and i cant even get it to spin the stock tires on the street when i floor it from a dead stop. Its gotta be the tune, im gonna contact PatG and see what he thinks.
  4. Likes -Ray- liked this post
  5. #14
    Sep 2011
    Gotta turn off ESC
    When I talked with Rick long ago about cams, the little Lunati ran best of 11.8x@120ish with a drag pack, intake, exhaust and 3.45 gears
  6. #15
    Dec 2012
    When Rick does the build, he mills the heads for a decent bump in compression. He also runs A LOT of timing so he is usually on race gas. He's big on weight reduction too. His cars maximized to run at the track. Just running the same cam he's used isn't going to get you the same time. Then there are things like driver experience, track prep, weather/DA, etc. If it were easy to go fast, everyone would do it.
