Can anyone comment on the drivability of the 102mm TB with a Maggie? I know removing the restriction will increase power, but does it become too touchy for the street?
Sent from my Rezound using Tapatalk 2
2009 G8 GT MSM, Sport Pkg
Rotofab, Magnuson TVS1900 w/3.3", Ported Blower Tub, PB 10% OD 8 rib
Blitz Ls250 heads pocket ported w/LS3 valves, PSI 1511ML springs, YT 1.85 RR, 7.450 PR, Comp FSL AFM cam
Kooks 1-7/8 mids, Corsa, ZL1 converter, PPV alt
My Garage
Well im gonna order one tomorrow and I'll know what it takes to make it work and if i notice a difference, won't have any dyno results or anything though. I thought I herd it needed more than just opening up the maggie thats why I asked. If i would have know for sure thats al it needed it I would already have it and it would be on, Just installed all 4" tubing and a ls7 4" maf, even got the part from roto-fab that reduced down to 4" insted of 3.5"
09 GT, Maggie 2300 3.2 pulley (12lbs with ported blower), Kooks 1 7/8 long tubes, no cats, Magnaflow cat back, Livernois 1c cam with dod delete, 3,000 stall, Alky Meth Injection, BAP. Best time 11.37
wasnt 100% complete but pretty much done
Ive had this setup on there for about a year now and can say just plain awesome. If I remember, I posted a you tube video under 102mm Nick Williams TB or something like that on the car. Just saying.
09 G8 GXP Panther Black is UNDER THE KNIFE!
