Results 11 to 20 of 46
Thread: P0633 theft deterent error on Replaced ECM? car wont crank!!
    Beyond Help gr8lover's Avatar
    SE Michigan
    Make sure the battery is fully charged before doing the relearn.
    Will do... car has been sitting so long... this could be an issue for sure!! I will make sure it is all charged up!!! thx
    I will have the tuner try this on Sunday.... thanks!!!!! I am hoping it works!!!!
    Tuner... on SUNDAY... that's awesome! :-)
    SE Michigan
    UPDATE:
    Tried procedure 3 full sequences... (3 times of 3 times each...) and still there... and wont even try to crank.....
    saw a earlier post if there is no keylock symbol on dash then ECM is bad... but I do have the keylock symbol......
    so no luck so far!!!!!!
    going to check all the fuses and starter wiring.. but still has the darn p0633 code....
    Mad Apprentice Tuner edmanet's Avatar
    MD
    Stupid question but ....Did the dealer put the correct vin in the ECM ?? For some reason it sounds like the modules
    are communicated with each other.
    11.350 @ 118.66 / 1.57 60ft [300 DA]
    RPM tune, PatG cam, FAST 102, L92 heads ported by Greg Good, Kooks 1 7/8 headers,
    RotoFab 102mm CAI, LS3 maf, UDP, JBA wires, Meziere water pump, SJM linelock,
    Circle D 3600, 3.27 diff with Truetrac, GForce HD axles, Pedders bushings, Spohn trailing arms,
    Camaro rims on the street & CCWs at the track....... SOLD
    Looking for a 00-02 Camaro SS with A4
    Central Florida
    Quote Originally Posted by edmanet View Post
    Damn. Good point/question.
    Central Florida
    I still think its the security relearn thing. I dunno if that backyard procedure actually works though.
    Lucky SOB G8GT721's Avatar
    MA
    It does, I did it on my car. Post 71 in my aps TT Install thread has a link to how I did it. It's a bitch and it has to be exact. If I remember right I made sure every thing was off and reached through the drivers side window to make sure nothing else electrical happens on the car
    2008 White Hot G8 GT
    SLOWHAWK Tuned
    My Garage
    SE Michigan
    Quote Originally Posted by G8GT721 View Post
    We did it exactly like your posting..... but still no go... may try again...
    but what does the phrase in the instruction mean "the procedure will not learn the immobilzer prerelease password or the challenge/response data".... how does it get to do those things?... anything special have to be done?..... hmmmmm
  9. #19
    SE Michigan
    do you know is there a way to check with HP tuners if the VIN number was put in correctly????.... or do I need a dealer to do that?.... my dealer seems to not be able to do anything with the ECM alone... they need it in the car.....
    I wonder if I can get a loaner or something from someone like Vector to see if it is a ECM issue or some other wiring issue.... I will call them in the morning... trying to move the car back to the dealer is a real pita....
  10. #20
    Vendors
    Send it to me I'll check it out I'm guessing they didnt program ANYTHING into it so its blank; I can program it for you.
