Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Anyone near Anderson SC?
    Central Florida
    Rick, see the last picture at this link:
    http://www.bmrfabrication.com/INSTAL...13_install.pdf
    This is why I'm asking. I have these parts on my car and want to know if your loop will conflict.
    Central Florida
    Quote Originally Posted by Rick@Metco View Post
    As of now, we are only working on a front loop.
    The loop is two pieces (mount & hoop), and the installation of the mount requires the opening of two holes in the crossmember to accomodate the 7/16" bolts. The holes are pre-existing, but they are partially blocked from the factory and must be enlarged slightly.
    We may pursue the development of a rear loop at some point in the future.
    Oh, ok, I was under the impression you were making front and rear loops.
    Anderson, SC
    ..I have these parts on my car and want to know if your loop will conflict.
    Nice parts...
    There should be no interference with our loop.
    Central Florida
    Nice parts...
    OK, let's get it done then
    Lancaster/Philly PA
    whats a loop?
    all the DICs I have seen looked the same.
    its a good thing I didnt go into a history of my experiences with all the DICs I have seen. Domestic, import, euro I have seen them all!
    Central Florida
    Driveshaft safety loop. Keeps shaft from contacting the ground and pole-vaulting your car if the shaft breaks at the front.
    and yes, a car will polevault straight onto its roof in some circumstances, I've seen it done.
    http://www.youtube.com/watch?v=Uzpbz5aLJms
    Central Florida
    I saw a Ford go straight over onto the roof at the strip when I was a kid.
