Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Looking for GM bulletin PIP4395F
    Sep 2011
    all the people that work for dealerships live with a concept that car is a car just to use it and abuse it without realizing that some of us are very passionate toads their cars and want the car to work flawlessly just like when it were new. So when you tell them you feel something wrong they think you are nuts as long as the car runs and no lights are on then its fine. I have not had any experience with any other brand but GM so I am very curious to find out if Toyota or Nissan works the same. Lately I see these people joining the boards that are supposedly GM representatives as soon as you create a thread that you are experiencing an issue they write to you please contact your dealer to resolve the problem. Most of the dealers are no help at all. You are lucky if you find a good one that will work with you and help you resolve your issues.
    Senior Member macvicar24's Avatar
    Gilroy, Ca.
    Quote Originally Posted by SRG963 View Post
    It's not G8 specific...
    Do you have a clunk when shifting from P to D or P to R after a cold start?
    Do you have any abnormal gear shifts, not like the other shifts?
    You said that you have a 2-3 flare, correct?
    It's better to complain about specific problems, and suggest the GM bulletin as a fix. Let them diagnose to be sure.
    I do have an occasional clunk from P to R. My main complaint is manual mode 2-3 shift. On 60-100% acceleration, shift from 2-3 pauses then slams hard into gear.
    My slight clunk from p to d or r was remedied by adding a bit of fluid... when I installed the trans cooler I redid the fill routine and since then, silky smooth. Those of you with the clunk, have you checked that?
    Beyond Help SRG963's Avatar
    Charlotte NC
    Quote Originally Posted by macvicar24 View Post
    This is EXACTLY what I had/complained about, turned out they, from my paperwork, "found seals from valve body to transmission case were distorted and leaking".
    Betting the clunk into gear is also caused by this.
    This is the exact wording....
    They found the car had "double engauge" when moving from reverse to drive, checked parameters with tech 2, all were good. Line pressure normal, fluid ok, removed valve body/module assembly and found seals from valve body to transmission case were distorted and leaking, replaced transmission seals, refill fluid, reset shift adapts.
    Trigger
    PRAISE THE LOWERED
    Gilroy, Ca.
    Interesting. I have a feeling with my local dealer they will check it and say its normal. I thought about driving it hard and keep slamming 2-3 shifts until it breaks. Then they will be forced to fix it. It sucks with these dealerships. They really want your car to come in busted. They have no idea what prevention is.
    Charlotte NC
    That was one of the three complaints I had related to the transmission. They didn't test my 2-3 shift, as they found the "clunk" into gear problem enough to investigate.
    Trigger
    PRAISE THE LOWERED
