Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Pro charger crankcase pressure
    Beyond Help gr8lover's Avatar
    SE Michigan
    Quote Originally Posted by Crazy8 View Post
    Does your valley cover breather have a check valve on it? I had mine vented, but it kept throwing a lean code, so I plugged it up. I did not have a check valve on it.
    No mine does not have a check valve in it...... no codes...... now I am trying to remember which valley cover I have.... not sure if its the one with the pcv orifice in it or not... but I am positive it doesn't have a check valve in it....
    Feb 2009
    Hope Mills, NC
    Vent the engine and get rid of the vacuum. Drill the rear PCV on the drivers side and run both the drivers side and passenger side valve covers to a vented catch can.
    Senior Member G8GTSBM's Avatar
    chicagoland
    So will pulling vacuum from the rear of the drivers valve cover and venting the passenger to atmosphere with a filter and the valley cover sealed cause problems, if it's going to be tuned like this?
    09.5 GT sunroof sport premium stryker blue
    Vararam...TVS 2300...Solo Mach cat back...3.5 tips...DT Tri-Y LT...DOD delete...cam 225-230 617-613 113 lsa...Land Speed Development Stage2 heads...trunion upgrade...vigilante 2800 converter...160 stat...AEM wideband...PCMforless trans cooler...URP catch can...Audi style headlights...hood vent mod... Pat G tune...ZL1 pump
    Trans rebuilt by me.
