Thank you I'll order it.
12669528 is for the 2009.5 G8 dipstick tube and pan. Don't use that one if you have a 2008-2009 dipstick tube and pan.
They are not interchangeable. You will need to find a used older version dipstick.
-Greg
Damn good to know. you know if nothing else you could always upon oil change - before you start filling - but after draining.
Check the new stick - should be dry.
Pour in 6 quarts - wait 5-10 minutes - check stick - should show I hope if it does show - MARK THAT
Pour in another 2 or 2.5 - wait 5-10 minutes - check stick - see where that ends up. mark that. now you know where it should end up.
If getting any other stick or the like doesn't work out for you. OH and maybe try the pull apart and scrap yard internet sales. I mean sad to say but enough have been wrecked.
I'm not able to look now. Is the hole in the block still there, just plugged or whatever, for use of the newer style of dip stick? Then plug the pan hole? I know that's not exactly an "easy" solution, but maybe something that's necessary if parts run all the way out? (although I'd imagine there will "always" be junkyard stock)
