Page 16 of 20 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 199
Thread: Offset Reference Ranges - "Will it Fit?"
  1. #151
    Banned
    Oct 2013
    Dix Hills, NY
    Quote Originally Posted by SIX.OH! View Post
    Oh ok. That's easy enough. I didn't know it had the offset stamped too.
    Yup everything is on there offset will begin w/et.
  2. #152
    Member SIX.OH!'s Avatar
    Dec 2012
    Temple, TX
    Only had time to pull off one wheel real quick, but the diameter was all that was stamped on it (except the max load and some standards codes on the spokes). Doesn't even have the wheel width - says "20 x" then has a little rectangle where the width should be. Weird. It has A27 stamped in one spot. That wouldn't be the offset would it? Attached a picture - wheel looks bad from the back - yeck. (doesn't help that they're filthy - caliche gravel road and rain on Sunday)
    "Elvira" aka "Red Nasty": 2008 Liquid Red G8 GT - Mustang Dyno before several mods: 376rwhp, 384 lb-ft tq - PowerBond 25% UDP, Modified Spectre/Rotofab CAI, LS7 MAF, tb ported by Yours Truly , Taylor Thundervolt wires, Kooks 1 7/8" LTs, Solo HFCs, QTP e-cutouts, Solo Mach Shorty, Camaro SS Deep Sump Trans Pan, Norris Motorsports Catch Can, TUNED by PAT G, Brembo GXP Front Brake Kit w/ StopTech Street Performance pads, Gunmetal TSW Nurburgrings 20x8.5 +43 front and 20x10 +35 rear, 255/35/20 BF Goodrich G-Force Sport Comp 2 and 285/30/20 Michelin Pilot Sport A/S+, rolled and pulled rear fenders with fender-bumper joints shaved, GXP rear struts, BMR rear end links, BMR Differential Bushings, "G8 GT 6.0 Liter" Trunk Badge, "L76 6.0" Sideskirt Badges, Black Painted Accents , GXP Rear Diffuser, Bohnman Chin Splitter, Lloyd Rubbertite Floormats.
  3. #153
    Beyond Help Slizzo's Avatar
    Newington, CT
    Looks like the manufacturer didn't write it in.
    Offset is the measurement of the distance that the mounting pad is from the centerline of the wheel (width wise). So, on a 9" wheel, you'd measure where the mounting pad is from the 4.5" centerline on the wheel. Positive offsets are towards the face of the rim, negatives are toward the inside of the wheel (in relation to the vehicle.)
    A +40mm offset on a 9" wheel means that the mounting surface is 40mm outside (again, in relation to the vehicle) of the centerline of the wheel.
  4. #154
    Dec 2012
    Temple, TX
    Thanks! I'll try to check that out today - might be tomorrow. Do you have any pics of your summer setup by chance?
  5. #155
    Newington, CT
    All over the forum here already, search for posts by me.
  6. #156
    Dec 2012
    Temple, TX
    Finally had a chance to take the wheels off to measure the offsets... only to find that the measurement were indeed stamped on the inside the wheel - on the edge. They are actually 20x8.5, not 9.5 like I thought, and the offset of all 4 wheels is 43. Why the previous owner spent that much money and decided to get all 4 wheels exactly the same size/offset is beyond me, but that's what I have now. So, I've heard that a 275 is the max for a wheel that is 8.5. Should I get 275 all around or is there any benefit from a little narrower (like the 255 that I have now) in the front and 275 in the back? Currently looking for pics of a 275 on a 8.5 wheel to make sure it won't be too much bulge. I know though that brand will affect that.
  7. #157
    You can add an inch to the wheel. Weldcraft wheels in Livonia, MI can do it.
  8. #158
    Jul 2014
    North Dallas, Texas
    I'm running OEM 20" camaro wheels. I haven't had much time to research, but I blew a tire out today hitting a pothole, and possibly did damage to the wheel.
    I already need two new tires, so I am looking to possibly replace them all. What is the better option for a stock height vehicle? I MAY go lower on springs later on, but I also want more sidewall for protection that I currently have.
    I know this has probably been asked a million times, but I am limited on free time, and could use a quick reply. I will research when time permits as well. Thanks for any advice. I need to have the car up and running ASAP.
    Oh, and screw Dallas County and their crappy roads!
  9. #159
    Newington, CT
    275/30/20 rear 245/35/20 front. Best bet for the G8.
  10. #160
    Jul 2014
    North Dallas, Texas
    Will a 35 series work well in the rear?
