Page 12 of 45 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 447
Thread: Magnuson 1900 Project- over-drive Cog, Porting, & Cutting out restrictions....
  1. #111
    Quote Originally Posted by Doug Hilliard View Post
    Very excited about getting this done! Thanks to Rick for getting me in so quickly, Greg @ Pace for getting the pump out Monday and blazing the trail along with Blue-Mayhem, and Carl @ Vaporworx for good support on the controller and making up a new wiring harness for me the same day I contacted him so the pressure sensor can be mounted at the fuel rail and getting it shipped the next morning!
    Congrats Doug... a couple of us guinea pigged this one... theres a VERY slight delay as it builds pressure under tip-in and reacts to throttle/boost... but otherwise is amazing and has proven to be very reliable!!! Good luck and enjoy!!!
  2. #112
    Apex, NC
    I appreciate everyone's efforts who have already done this; those of us following you are the beneficiaries! My old setup worked for a while but I expect even with a slight delay, this setup is going to be much better all the around than my stock pump running at 20V at full boost! I look forward to taking it for a drive when Rick finishes it up Saturday!
  3. #113
    VIP Member blue-mayhem's Avatar
    Huntsville, Tx
    Doug you'll love the new setup.... Rick if you come into to any problems with the install just let me know because I probably had the same issue. Don't forget to cut the tab in rotate the pump counter clockwise so the fuel gauge is correct.
  4. #114
    Feb 2009
    Hope Mills, NC
    Quote Originally Posted by blue-mayhem View Post
    Will do! Thanks!
  5. #115
    Jan 2012
    Dayton, OH
    Rick / others - I have what may be a dumb question. I read the Camaro 5 board from time to time, and it looks like getting 600+ rwhp with just a pulley, "balancer", CAI and tune is not too difficult with the ZL-1. And that's without headers or even a catback.
    I have a GXP with a more aggressive cam (but still stock) than the LSA and I'm contemplating a maggie. However, I don't see those types of numbers with other that have installed maggies. Can someone just put the pulley, CAI and tune kit on a 1900/2300 on a G8 and see these types of numbers? If not, what are the differences? I understand that with the GT cam, it creates too much boost - but i have quite a bit more lift than a GT or LSA. It seems like maggie'd GXPs are only putting down 550 range with aftermarket cams.
    2009 MSM GT. Kooks mids, Corsa, CAI, Comp Thumpr 219/233 on a 114LSA and tune. 370 rwhp, 371 rwtq - Sold.
    2009 PBM M6 GXP. Corsa, Rotofab CAI and tune - 404 rwhp and 404 rwtq. Maggie 2300 to come . . .
  6. #116
    Feb 2009
    Hope Mills, NC
    Quote Originally Posted by js59 View Post
    The power is the same, the motors are 6.0 vs 6.2 but it is just dynos and tunes where you see the difference. ZL1 is a completely different setup for a supercharger so getting power out if a ZL1 vs a 2300 is different. For a GXP, upgrade the valve springs, get 1.85 rockers, pulley the blower 3.0, add methanol injection, and you'll have plenty of power.
  7. #117
    Jul 2011
    Somewhere in America
    ZL1's are using the blower with the longer runners are they not?
  8. #118
    Apex, NC
    Quote Originally Posted by rocket69GTP View Post
    Yes they are.
    CTS-V fuel pump and Vaporworx controller are on the job and doing great! Car is running like a monster again!
  9. #119
    Apr 2010
    Ocala, FL
    I'll eventually follow and do a fuel pump like you have along with methanol injection.
    2008 G8 GT
    Rick Crawford Tuned
    663/596 Rwhp rwtq for now....
    10.87 at 133 1.59 60ft
  10. #120
    Get Some hartigan85's Avatar
    Dec 2009
    Alamogordo, NM
    Porting my blower this coming weekend, I have all the non-ferrous grinding bits showing up tomorrow. Any tips or anything I should be weary of while grinding away?
    Atmospheric Acquisition
    Pictures
