Page 12 of 82 FirstFirst ... 210111213142262 ... LastLast
Results 111 to 120 of 816
Thread: G8 Grrrr8 parts list
  1. #111
    Buda, Texas
    Part numbers for the chrome trim around the front kidney grills?
  2. #112
    Beyond Help mi04se1's Avatar
    Dec 2009
    White Lake, MI
    The chrome is part of the grilles.
    R-92201780
    L- 92201781
    or vice versa cant remember
    09 Liquid red G8GT
    8000k hid's
    Inalfa sunroof
    Rotofab cai & radiator cover
    BT from 09.5
    GXP fascia & diffuser
    13.207@107.11
    338 hp/337 tq
  3. #113
    Senior Member hulkss's Avatar
    Chaska, MN
    G8 GT part number for rear drive shaft (axle) hub nut and washer.
    Gotta pull the hubs to put in longer studs and the manual says to use new nuts and washers.
  4. #114
    Quote Originally Posted by hulkss View Post
    05-11-2009
    Quote Originally Posted by Greg@PacePerformance.com View Post
    Here are the part numbers and prices.
    Washer - 92139022 $10.63 each
    Nut - 92138989 $22.45 each
    For the washer I had Part number 92189154 here but that could be an old superceded number.
  5. #115
    Boardman, Ohio
    05-11-2009
    Paul that number is for the axle retainer clip that holds the axle into the diff.
    92139022 - Washer
    Two designs for the nuts now.
    92138989 - 1st design for vins up to 9L191080
    92216821 - 2nd design for vins after 9L191081
  6. #116
    Austin
    Default Part Numbers for Keys
    I need the pn's for the keys, both the fixed and switchblade (both parts). Also any recomendation for where to buy. Thanks.
  7. #117
    Boardman, Ohio
    Quote Originally Posted by JMF32 View Post
    89027354 - Fixed key
    89027333 - Flip key
    Dealer only items must be ordered pre cut unless you find a delaer with the special cutter for these keys.
  8. #118
    Dec 2009
    White Lake, MI
    Yep, got the bulletin right next to me. I have to get a 2010 SRX key for a customer. Dam laser cut.
    09 Liquid red G8GT
    8000k hid's
    Inalfa sunroof
    BT from 09.5
    13.207@107.11
    338 hp/337 tq
  9. #119
    Lebanon,Indiana
    Hood 92202939
    Safety Catch [16](not the part you want [18], its all I can offer) 92202947
    Upper Grille Right 92201781
    Upper Grille Left 92201780
    Fender (Left or Right) 92202891 Various GM sites show different sides
    Fender (Left or Right) 92202890
    Trunk Lid 92218258
    what is part # for the lower grills #3. who has them? Even used would be ok
  10. #120
    Banned
    Jan 2009
    Chicagoland
    Nevermind found it.
