Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 145
Thread: Build thread for rebuilding the 6L80
  1. #111
    Colorado Springs
    No, but the aftermarket clutches seem to be more sensitive to overheating. Just make SURE you install a BIG trans cooler and you should be fine. But you will have to machine the apply disks to make clearance for the extra clutches.
  2. #112
    Sep 2011
    Houston
    I think I will be going back with a brand new OEM transmission this time. Seems noone really has a good BUILT 6L80E out there on the market. I was looking into century but it seems they are still experimenting with the clearances and tolerances.
  3. #113
    STL
    Quote Originally Posted by XplicitPerformance View Post
    Best idea at the time i think.Before i sold the G8 was telling myself i'd just go the same route whenever mine went.
  4. #114
    Feb 2009
    Hope Mills, NC
    I am still for machining for the extra 3-5 and 4-5-6 clutches using factory fibers and steels. That is the best upgrade. The 3-5 I cut the cage down and notch the 1-2-3-4 endplate. The 4-5-6 gets a thin end retaining ring and .035-.040" cut off the step in the end plate. I run .065-.075" clearance. Too much and the clutch plate will hang up on the drum retaining notches on the teeth.
    The Alto kit is junk. PERIOD. Anything that is worse than stock is junk. Dougs trans has held up great with the setup above and doesn't get cut an slack....
  5. #115
    Feb 2009
    Hope Mills, NC
    so is there anything special they do besides an extra clutch?
    "they" don't do it. The extra stock clutch is my doing....
    Alto tried to make some weird clutch arrangement that uses a hybid fiber plate which get another 2 clutches. They are steel one side, clutch on the other. But this design makes everything paper thin and just burns up with an power. To make it worse, the clutches are applied from a thin outside ring on the piston and the clutches are so thin, they deflect so it only grabs on the outside edge of the clutch.
  6. #116
    Sep 2011
    Houston
    Quote Originally Posted by shane View Post
    Yeah looks like thats the ticket. I am going to give another factory 6L80E the go ahead one more time. Maybe that will give me time to convince the boss to let me put a 4L80E in her car. She hates losing the extra 2 gears but I like the durability especially with the plans to crank things up.
  7. #117
    Member BODYSHOPG8's Avatar
    Dec 2012
    Tipton, IN
    thats a nice write up... never seen one that involved for a trans on the forum
  8. #118
    Jan 2009
    Quote Originally Posted by G8-4-Speed View Post
    i wish i read this before i order altos,, can you please elaborate in more details -pics if possible- on how to rebuild using factory clutches?
    where to get a thinner retaining ring for 4-5-6?
    anything to be done to 1-2-3-4 or 2-6?
  9. #119
    Feb 2009
    Hope Mills, NC
    http://parts.nalleygmc.com
    Pull up our trans and they list all the retaining rings available. I believe the ones you need are:
    24233407- 4-5-6 thin ring
    24240194- 3-5-R thin ring *** you have to machine the clutch stand or end plate to get clearance on this clutch pack for the extra clutch and steel.
    You need a
    fiber kit- 24248008
    Seals- 24260143
    1-4 steels- 24258080- 5ea
    3-5-R-steels 24258082 -5ea
    4-5-6 steels 24258083- 7 ea
    3-5-R fiber 24235681 - 1 ea
    4-5-6 fiber 24224158 - 1 ea
  10. #120
    Sep 2011
    Just wanted to add that my trans is still working great with the alto clutches. I went with .095 clearance on the 35R if I remember correctly. The STS-V trans has a shallower 35R drum and there is not enough room for all the clutches. I had to leave one out. The most power I put through it was 575/621. I removed the turbo and went back to the stock supercharger so I'm down to 480/490 now.
