Yes, correct.
There is a bulletin to fit a shroud or deflector over the AFM oilpan relief valve.
#10-06-01-008B: Engine Oil Consumption on Aluminum Block Engines with AFM
#10-06-01-008B: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) (Install AFM Oil Deflector and Clean Carbon from Cylinder) - (Mar 7, 2011)
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=168468
