02-04-2015, 05:12 AM
#101
hflores3
Thanks! Do you think Crazy Paul would have the part number? (I should really have "everything" in hand before starting)
I'm sure he could get it but honestly I'd just go to a local dealership and order it; they might even have one. I doubt it's very much. I think I ordered one from a dealership locally. I'm not sure you actually have to take it off. I took mine off but I'm pretty sure you can get the alternator out without disconnecting the line to the PS pump.
02-04-2015, 09:04 AM
#102
It is not required to remove the PS line. I only had to remove mine when the new PS pulley got stuck and I needed to remove the pump completely to get the damn thing back off.
02-04-2015, 02:16 PM
#103
Affirmative. I can't hurt to have it there if needed. Lord knows crap breaks when I'm working on it.
03-01-2015, 11:47 AM
#104
Guess what Henry. Since I got a new tool cabinet I was cleaning up the garage some. I found those damn alternator washers and nuts!
03-13-2015, 02:57 PM
#105
Finally got the 8 rib installed. Sweet!
03-15-2015, 05:39 PM
#106
hflores3
Congrats Henry!!!
03-16-2015, 08:05 AM
#107
By the way:
a) Thank you "TooManyHobbies" I really appreciated the coaching. Damn nice of you.
b) Thank you "Doug" - you did the original research and shared it! Damn nice of you.
Just being a stand up guy -- I appreciate all that you did to help. This 8-Rib is damn cool!!
03-16-2015, 08:06 AM
#108
TooManyHobbies
LOL!!!!!! No worries....
03-19-2015, 07:58 PM
#109
hflores3
By the way:
Totally my pleasure! I've learned a ton from many on here and am delighted to be able to contribute something! I'm really glad you like the 8-rib system; I did too!
10-01-2015, 06:46 PM
#110
Such great work on here! Looking to maybe leverage some this knowledge. Does anybody know if this is still applicable on a 2009.5. I know the accessory belt routing is different.
'09 G8 GXP M6
De-badged - Tinted side marker - blacked out window trim - 5k HIDs Low beams & Fogs - Red Calipers - Sharkfin
TVS1900 - LS9 injectors - 1 7/8 LTs -3" SOLO - CAI - MGW Shifter - McLeod TwinDisc - Squash Performance Fuel - Catch Can
BMR trailing arms - Eibach Pro-Kit - GForce Half-shafts - '09 CTS-V wheels 19x9/9.5 w/255-285
__________________________________________________
'91 Firebird - Fastburn crate motor, T56 6speed - gone but not forgotten
