Page 1093 of 1304 FirstFirst ... 935939931043108310911092109310941095110311431193 ... LastLast
Results 10,921 to 10,930 of 13033
Thread: What did you do to your G8 today?
  1. #10921
    Jan 2015
    North East, MD
    Replaced the passenger presence module so my passenger air bag will work again and the car will stop reminding me every damn time I start it there's an airbag fault...
    Matt Jones
  2. #10922
    VIP Member pir4te's Avatar
    Oct 2011
    Barossa Valley, South Australia
    Updated the trans tune to 2016 spec, upped the desired slip of the stock stall, unbelievable difference.
  3. #10923
    Quote Originally Posted by pir4te View Post
    2016 spec?
    Upped desired slip?
    Explain for the noobs?
    Sent from my LG-D800 using Tapatalk
  4. #10924
    Oct 2011
    2016 spec?
    Upped desired slip?
    Yeah just that the parameters for calibrating the 6L80 up until now have been rather conservative, and dangerously hit and miss. Even by comparing box tunes from the notable tuners.
    Whereas with the latest LS3 settings it is radically different, but OFC factory safe. More than 95% of the parameters are compatible with our controller so I thought I'd reprogram ours to the new specs and run it up the flagpole.
    What a difference! However I suspect that on an unmodded car the extra apply and release pressures wouldn't work else need more desired slip in the stall.
    What's changed:
    Shift control speed and rpm
    Shift speed
    Shift pressure
    Torque convertor control speeds - apply and release
    Torque convertor slip
    The last one is a duesy, basically every box tune I've bought commands desired torque convertor slip at 0% which means more direct but no multiplication. The new stock tune ups that to 10%, which is a breath of fresh air after five years without it.
    Of course I upped that to 15% and with my setup runs best I've ever had. Very happy.
  5. #10925
    Dec 2015
    Just ordered a Rotofab CAI with some tax refund money.
    '09 WH G8 GT
    Premium/Sport
    Red/Onyx
    Rotofab CAI
    Cortex 93 tune
    20% tint
    I just wanted one.
  6. #10926
    VIP Member kevinm0131's Avatar
    Nov 2008
    Oxford ohio
    Hooked up the battery Tender!
    Kevin
    2009 SRM G8 GXP A6 + Roof
    Go
    Vararam CAI
    VMS "Stealth" Dyno Tune
    VMS HSRK
    GTPprix's hacked Atari gauges
    Doug Thorley LT's
    Show
    PB
    12.986 @ 108.78
  7. #10927
    Quote Originally Posted by kevinm0131 View Post
    Still been driving mine. Looking at the forecast, it is going to sit this week out though.
  8. #10928
    Reinstalled the oil pressure gauge that I needed to RMA to get fixed. If it goes bad again and tries to ruin another track day I can pop off a panel and snip the wires in 60 seconds or less
  9. #10929
    Sep 2009
    VT
    Configured the output of an AEM 30-0300 WB controller/gauge (custom flash) to drop the AFR (Lambda) onto the CANBUS such that is is read as a PID. 100hz sample rate, no more ground offset.
    Sport /Premium
  10. Likes sixt9stang liked this post
  11. #10930
    Dec 2015
    Installed a Rotofab CAI and flashed it with the Cortex Rotofab 93 tune.
    '09 WH G8 GT
    Premium/Sport
    Red/Onyx
    Rotofab CAI
    Cortex 93 tune
    20% tint
    I just wanted one.
