Page 10 of 20 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 199
Thread: Offset Reference Ranges - "Will it Fit?"
  1. #91
    Senior Member Dagoon's Avatar
    Nov 2009
    Ontario, Canada
    hey everyone. im in the process of buying new tires and heres my current list:
    Front:
    245/40/19s (stock size)
    Rear:
    275/35/19 OR
    285/35/19
    Does that sound good? or what should I tweek here? I want to have no ABS issues and my car is stock height. Should the rears be a 30 instead of a 35?
    2008 Pontiac G8 GT #670
    Livernois Stage 1 Cam, PI 2800 Stall, RotoFab Intake, 25% UDP Pully, Kooks 1 3/4" LT Headers with High Flow Cats, Kooks X-Pipe. Intake Cover Delete, MT 275/40/17 Drag Radials, Rear Muffler Delete, Mobil 1 Oil
    Livernois 91 Tune
    12.1 @ 112mph 1/4mile 1.7/60'
  2. #92
    Southern NJ
    Quote Originally Posted by Dagoon View Post
    Front:
    Rear:
    275/35/19 OR
    285/35/19
    Front is 26.7"
    275/35-19 will be 26.6"
    285/35-19 will be 26.9"
    Height-wise/ABS/etc; you are fine with either combo.
    No, you don't want a 30 series for those combos. Way too small tire for that type of setup.
    R.I.P. Charlie
  3. #93
    Nov 2009
    Ontario, Canada
    ok now my next question is with the 35 size will they rub?
    Livernois 91 Tune
  4. #94
    Southern NJ
    Height-wise, no they won't rub. I run a 26.9" tall rear tire with no height-rub issues.
    Width-wise, depends on the width and offset of your wheels.
    R.I.P. Charlie
  5. #95
    Nov 2009
    Ontario, Canada
    rims are 9.5 wide, and offset is 45
    Livernois 91 Tune
  6. #96
    Southern NJ
    My rear setup is 285/35-19 on 9.5" wide +45 offset (just like you are describing). They did not rub until I added a full-size spare and one additional passenger and only on heavy dips or bumps and then they rubbed very slightly and very infrequently.
    A 275 would probably give the extra clearance not to rub under these conditions because they are not as wide and not as tall.
    I had my fenders rolled and slightly pulled and have no more issues. I also added a 5.5mm spacer to push them outward even further and they still don't rub.
    R.I.P. Charlie
  7. #97
    Nov 2009
    Ontario, Canada
    i see you have the hankook tires, how are they? it was either that or the nitto invos
    Livernois 91 Tune
  8. #98
    VIP Member BATOYGIO's Avatar
    Nov 2009
    Queens, NY
    So I looked through and found that 40 offset on a 19x9.5 will work up front, but the rim I am looking at is 41mm offset. I know I can get a spacer to fix that but was curious, would a 41mm offset not rub the front strut on a stock car?
    '09 Liquid Red GT
    Kooks, VMS, Roto-Fab, Solo, BMR.
    12.86@109 1.98 60ft
  9. #99
    Beyond Help Slizzo's Avatar
    Newington, CT
    Quote Originally Posted by BATOYGIO View Post
    It would probably be close, but you should be OK I would think.
  10. #100
    Southern NJ
    I like them for the money. They came highly rated by several car magazines.
    In my experience, they do well in wet weather. I run them from about April to Oct/Nov.
    Cornering, they've been fine for this heavy car.
    Their straightline, dry traction seemed better last year when they were newer but it's also not that hot out yet. I don't have a lot of miles on them and plenty of tread left.
    They stick better in temps above 70 degrees. The hotter it gets, the better they grip in a straight line.
    With consistent temps below 40/45, I would take them off the car as they are too slippery when it gets near freezing.
    I don't find them noisy.
    @ SLizzo: what's your opinion on your Hankooks??? I'd like to hear too and it would help out Dagoon.
    R.I.P. Charlie
