Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Octane
    Beyond Help p71's Avatar
    A-town junior, TX
    Default Octane
    I suspect that there might be a little bit of a mislabeling issue at some local pumps... is there any way to check that the octane number listed on the pump is accurate?
    The source of my suspicion is as follows...
    1) There are a few gas stations owned by the same retailer that get their fuel out of the same tanker trucks but some stations label their premium as 91 others as 92 and still others as 93.
    2) My buddy drove to Dallas and got his STI tuned using a tank of gas from here and his tuner said that the he was having to be very conservative and leaving about 30 HP on the table because the logs were coming back showing the car running like it was on 91 octane (lots of anti knock retard). STIs are extremely octane sensitive (turbo... lots of boost, lots of heat, small motor)
    11 Mopar 11 Charger
    11 Ram 1500 White Crewcab Hemi 4x4 Sport TRADED
    10 F150 Raptor Black 5.4 Supercab TRADED
    09 GT Black Premium Sport TRADED
    Mods: Livernois Stage I Kit with ported intake and TB, Livernois Tune, New Era OTR CAI, UDP, Kooks 1 7/8 catted LT, GXP Front end conversion, GXP mufflers, GXP rear diffuser, VMR VB3 19x9.5, Nitto Invo 275s, TMA 3202, 2 JL Audio 12"s, Limo tint.
    Upcoming Mods: GXP brake conversion, DBA rotors, Hawk pads, BMR Subframe Connectors and Trailing Arms, Pedders XA Street system, It is good to have a plan.
    08 GT Black Premium Sport RIP
    2 JL Audio 12"s
    Senior Member DewieJr's Avatar
    Mar 2009
    Dayton, Ohio
    Not sure if you can verify it or not, but I'd find one you can trust and stick with it. I only run 93 or 94 here in Ohio....we don't have premium as low as 91, thats in the western states.
    Mar 2009
    St. Croix, USVI
    the various grades of gasoline can be mixed or "tampered" with at ANY point in the fuel delivery chain of distribution. From the rack at the fuel depot, in the tanker truck, in the tank at the station and in the pump itself. Rely on past experience with what works best. Check with local consumer advocates and ask if they check octane.
    Rumbler
    5OH TERMIN8R Devilish34's Avatar
    Feb 2009
    Oxford,Pa
    What brand of gas?? I try and stick with Sunoco 93 or BP if I can find one.
    Retiring as the undefeated Cam only Record Holder 11.454@120
    Come and get the title bitches it's up for grabs
    Devil's Advocate Ktlplxm's Avatar
    Nov 2008
    Charlotte, NC
    BP is the only one I've found that works in mine. Unfortunately I have 3 stations within 1/2 mile but the closest BP is 6 away
    Winning may not be everything, but its still better than losing
    I don't know you. I don't know what have done. If you are looking to talk up a race for 3 hours, I can tell you I don't have the time. But what I do have are a very particular set of parts; parts I have acquired over a very long career. Parts that make me a nightmare for people like you. If you go home, that'll be the end of it. I will not look for you, I will not punk you. But if you don't, I will punk you, I will race you, and I will embarrass you.
    Senior Member PaFromFL's Avatar
    Jan 2009
    Ethanol (E10) might be a problem. Theoretically, it should reduce gas mileage about 3%, but in practice it is more like 10%. I'm guessing that modern engine controllers are optimized for pure gasoline and E10 throws off the calculations. They should add a letter to the octane rating to warn people that 91 octane gas is not the same as "91E". In my area, the pumps say "may contain up to 10% ethanol", so you never know what you're getting. Since the E10 scam actually wastes oil (harvesting, manufacturing, shipping by truck, 10% mileage reduction), we should outlaw E10 and deport the corn CEOs and their lobbyists back to hell by way of Guantanamo.
    2009 G8 GT, premium, sport, sport red metallic
    Roto-Fab CAI
    MagnaFlow 16887 Street Series cat-back
    Superchips Cortex: RotoFab 91 Octane, 25% TM, AFM off
    and splash guards (that look better than dirt)
    Addicted Member DQGTO's Avatar
    Dec 2008
    Kings Park, NY
    yeah in NY we get like 10% ethanol also. I always use Hess when I can. I have found that they have great gas compared to a lot of the other places around me. Sonocos are few and far between by me. Hess is my gas of choice and if not Hess I will go BP.
    Nov 2008
    Charlotte, NC
    yeah my local sunoco's only keep 92 and I can't run it.
    Feb 2009
    Oxford,Pa
    Quote Originally Posted by Ktlplxm View Post
    For the most part only the Wawa's have 92 around here. And I've only found one Sunoco that has 100.
    Administrator Steve's Avatar
    Olympia,WA
    Ethanol EVERYWHERE here... 92 max..
    found one place that supposedly had 94 close by and they went tits up
    -= R.I.P Charlie =-
    2008 Panther Black G8 GT 888 Edition #470
    Texas-Speed 418 LS3, Patrick G 234/242 114LSA+2 Cam & Livernois Ported Heads & Valve-job, Roto-Fab CAI & Radiator Cover, Fasterproms Ported TB & Manifold, ECM/TCM Tune by PatrickG, 1-7/8" American Racing Headers, Circle-D 258mm 2800rpm Converter, Powerbond 25% Pulley, Pedders xA Street II Kit, HSV VE GTS Fenders, HSV VE GTS 20" Wheels (285/30 & 245/35), 20% Tint, Holden Rear Sunshade, Empty Wallet Mod(tm)
    http://g8gt.blogspot.com
