instrument cluster dead
So, My cars battery went dead, I gave it a jump start and now my instrument panel does not work, no instrument panel lights, tach and speedometer do not work. I checked all the fuses, under hood, inside cab and in the trunk, all are okay. Any thoughts? anyone have this sort of issue before? Any help would be great.
Thanks,
Michael
Eli liked this post
Wow that really sucks how long was the battery dead?
Maybe unhook the battery and hook it up again
2009 Panther Black Metallic "
The Black Rat"
Current Modifications: Front end, Roof Pillars & Front top of roof has Clear Shield, Holden V8 6.0 Badges, Holden V Trunk Badge from Crazy Paul, UPR Catch Can, Corsa Exhaust & Roto Fab CAI. Spare Tire and Jack and Tinted Window's, hood scoops gutted, Poor Mans Heater Hose modification (holding up the hoses with zip ties), Painted the front dart to Panther Black.
Patrick Guerra's Tune July 12, 2010: 345 HP, 355 Torque on 87 Octane
![The man](images/smilies/th_theman.gif)
Patrick's & Kurt's install of Kooks Long tubes 1 7/8" w/Corsa Connection Pipes
11-3-10: 362 rwhp, 372 Torque and updated engine and transmission tune.
New Engine as of 10- 5, 2011. Patrick & Kurt's tune and dyno 10-19 2011:363 rwhp, 365 Torque 93 octane.
Sounds so
GRRRR8 BECAUSE RACE CAR
![Beer](images/smilies/beer.gif)
![USA](images/smilies/th_USAflag.gif)
7-1-14 Brembo Front Brake upgrade & Bohnam Front Splitter installed
![Thumbs up](images/smilies/thumbup1.gif)
Curt here
uhm did you check the fuses with a meter - IE test they are actually continuous. Some of the darker fuses are a bit hard to see versus knowing they are bad.
Curious - does anything in the car actually work.
IE do the headlamps come on - does the radio light up etc etc. IIRC there are fuses at the battery - I think 50 AMP jobs. Maybe I'm thinking of another car.
Finally I think there are 1 or 2 relays that have to close before it comes on.
Thanks for the replies,
texn884, i have unhooked the battery and even bought a new one. battery was dead for less than a week.
Napalm, I have not checked with a meter yet, Lights work, radio works the whole radio cluster works. atari gauges work, brake lights headlights and blinkers work on outside of car, the only thing that does not work are the instrument panel, speedomete, tach, gas gauge and engine temp gauge and all other warning lights on instrument panel along with the controls on the steering wheel do not work. Also the radio panel on the upper two corners where it tells you what temperature your cabin heat is at, I think it swithced to celsius. it usually starts and 60 degrees and goes up to 80, now it starts at 10 and goes to 30. other than that everthing else works.
Thanks.
Oh and I also replaced the llittle fuse block on top of the positive post on the battery as well.
![Quote](images/misc/quote_icon.png)
wisniewski98
Thanks.
May you please share if your issue was ever resolved and how? My car is currently behaving in the exact same way.
I know I am reviving an old thread. I have also tried PMing the OP.
