Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
Thread: Silicone Hoses
  1. #61
    Moderator LDM's Avatar
    Mar 2010
    Cape Cod, MA
    Quote Originally Posted by s/c'd cav View Post
    im guessing the 2014-16 chevy SS would be the same as the GXP , both using the LS3 and updated water pumps
    I believe the SS has an oil cooler like the PPV and Camaro that has a coolant line which tees into the upper radiator hose.
    Len
    White Hot 2009.5 Pontiac G8 GT
    TVS1900 | Custom Texas Speed & Performance cam spec'd and remote tuned by Patrick Guerra | LS9 Injectors | Rotofab CAI | Corsa catback | Kooks 1-7/8" LTs with catted connectors
  2. Thanks s/c'd cav thanked for this post
  3. #62
    Dec 2013
    phx az
    Quote Originally Posted by LDM View Post
    hmm , well that sucks then , thought it was worth a shot
  4. #63
    Administrator eric_cspan's Avatar
    Nov 2013
    Hatfield, PA
    If someone can confirm, we'll definitely do it then.
  5. #64
    Administrator Chewy's Avatar
    Bettendorf, IA
    I know someone with an SS... I'll see if he can get me detailed photos.
  6. #65
    Nov 2013
    Hatfield, PA
    If we can confirm they are the same hoses, I'll get originals in and get them done!
  7. Thanks Chewy thanked for this post
  8. #66
    Dec 2013
    phx az
    the SS does have a oil cooler and it does have a coolant line going into the upper hose
    BUT , the T for the cooler line , is a serviceable piece , not the best pic but should be good enough , so all the SS owner would need to do is cut a couple inches out of the hose and slip the T in and clamp it
    Attached Images Attached Images
  9. #67
    May 2013
    NYC
    Do these last?
  10. #68
    VIP Member MongosG8's Avatar
    May 2010
    Connecticut
    Quote Originally Posted by captainmal View Post
    Do these last?
    Yes they do. I still have a brand new set of the original blue Jettstreams. Much better than stock
    2009 White Hot G8 GT w/ Onyx/Red Int. Sport/Premium, No Sunroof, Garage Queen
    Borla Cat Back, VCM OTR Intake, DBA 4000 Slotted rotors and Hawk Ceramic pads, GXP Diffuser painted White, GXP Fascia, Crystal Clear side markers, Black Scoops, 20% Tint all around. 20" Camaro SS polished staggered, Shark Fin, Infinity 6032si front and Polk db651s rear
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
    "Mongo only pawn in game of life"
Tags for this Thread
