Send it to me, I'll measure it for you.
are new bolts required for lifter guides and rockers?
2008 White Hot G8 GT
(new)499RWHP/474RWTQ Mustang Dyno
(old)451RWHP / 498RWTQ Mustang Dyno
1/4=11.400@118.7 17" Drag Radials, stall, cam 1.77 60'
1/4=12.004@120.6 17" Drag Radials 2.03 60'
1/4=12.270 @118.3 on 18" All Seasons 2.08 60'
SLOWHAWK Tuned
If you can't say anything intelligent, say something loud and stupid
My Garage
if i get this http://www.texas-speed.com/p-644-n-m...iming-set.aspx
will i still need to get this ?
2) 12586481
Camshaft Sprocket
• Fits LS1, LS2 and LS6
• 4X camshaft gear
• 3-bolt design;
uses (3) bolts P/N 12556127
i'm trying to gather all my stuff up but don't want extra parts lol thanks i got 77,000 plus miles so i figured i might as well change it![]()
2009 SBM G8 GT
2007 Suzuki GSX-R 1000
thanks its getting cheaper and cheaper lol if i would have got a price on all this from my dealer i would have done this in 2009 lol its really not that bad $$$
2009 SBM G8 GT
Here you go.
Originally the GM AFM relief valve was Part Number 12594579, this was superceded in June 2006 by the new current Part Number 12608835.
The valve has a diameter of 19mm and has a hexagonal 17mm AF section at the top.
Underhead length is 14mm with only 11.5mm of it being threaded, the lower 2.5mm has no thread.
The thread is M14 x 1.50mm
A suitable plug IMO would be the Dorman Auto Grade Oil-Tite Drain Plug Part No 65386.
This plug comes with a copper crush washer to seal the thread.
65386 thread is M14 x 1.50
Hex head is 19mm AF
Underhead length is 12.3mm (you lose about 1.5mm of thread engagement due to the thickness of the copper crush washer, so the 65386 will still utilise the approx 11 mm depth of thread as the original valve).
Dorman 65386
The larger capacity ZL1 oil pan that Greg @ Pace had been selling.....wouldn't that come without the GM AFM releif plug? I've got one of those in the garage -- that my be my ticket - eh?
2009 G8 GT
628.5 RWHP on gasoline ---> ARH Long Tubes 1 7/8" & full exhaust / Magnaflow Mid Muffler / Cherry Bomb Vortex Mufflers / Magnuson 1.9 / Overdrive "non-cog" pulley system / Ported blower base / 2.70" Pulley / LS3 rockers with Trunion upgrade / Trick Flow x255 cylinder heads / 8-Rib Pulley system / Innovator West 10% Balancer / DOD Delete / Lunati Lifters / Custom CTS-V Patrick G Cam Grind / Wiseco Forged Rods & Pistons / Injector Dynamics 85lbs / 4.25" Air Intake Tube / 102mm TB & MAF Tube / 102mm TPIS Throttle Body / LS7 MAF Card / ZL1 Fuel Pump / JMS Fuel Pump Booster / VaporWorx Controller / B&M Tranny Cooler with fan / Circle-D Heavy Duty Rebuild & 265mm triple Disc Billet Converter / Camaro Tranny Pan/ Eibach Lowering Springs / BMR Front & Rear Sway Bars, LCA's, Control Arms / DBA 4000xs Rotors / Hawks Ceramic Pads
Great thread! It's really enlightened me on the whole project of cam swaps. This is something I'll be doing as soon as I take delivery of my new DD this spring.
Paul, is this valve the culprit that is spraying the crankcase full of misty oil and it then getting sucked through the PCV system and pooling the intakes and causing my burning oil smell? I believe there is a bulletin about a shroud or cap to be installed over this to prevent the oil spray? I'm about to give up on why my car fills with burnt oil smell for the first 500-1000 miles after a TOTALLY clean (no spills) oil change.
TLS
'09.5 G8 GT Sport Red
'05 Legacy GT
'04 GMC 2500HD 6.0
