The bolt labeled 3 in the drawing is M12x1.75x90mm and is GM part number 92139182. Bolt 9 is M12x1.75x125mm and is part number 92139036.
Len
Is it possible to have a diagram like this for rear suspension bolts? GM online sources only show components but not the bolts. Thanks.
Like these?
Whenever I'm looking for parts I use this website: https://www.tonkinonlineparts.com/pr...=0&searchTerm=
I've never bought anything from there but it's good for diagrams and figuring out part numbers.
Len
Since I had to temporarily drive her a couple weeks for the first time this winter. I took her our of the darkness again ..I gave her a body wash and undercarriage wash. I love this touch-less place we have near by. Under sprays and side sprays before cleaning with hot water.
R.I.P. Charlie (Mr GRRRR8)
R.I.P. Chris (Panzer Leader)
Thanks LDM, I have been studying Install instructions from BMR for rear components.. control arm, toe rod, trailing arm, for some of the bolts, instuctions show tighten initially to a torque value then an amount of degrees after. I believe this means bolt is TTY. In time I hope to install new components and replace one time use TTY bolts.
I installed led bulbs in sidemarkers ( behind wheel) it took about 3min. . I remember years ago when I was getting a sidemarker replaced under warranty. Dealer tech had car up in air and removing wheel well etc. It was unbelievable they didn't know how to work on the car.
Awoke it from being dormant. Prep space for mod pile reduction (cam, pulley, vertor, diff bush, arm bush)
Sport /Premium
Installed a front splitter today. Improves the look of the front end, it's those subtle little differences that eventually add up.
Got the front lines put on today. Fit perfectly. Awesome kit!
Those look familiar.....
Sure are nice, aren’t they??
