Travis ..You would figure in a hot state like AZ they would have at least a one car garage.
Ray .. try to find one that has a garage with 12" or higher ceiling. Nice lift would fit in there perfectly
R.I.P. Charlie (Mr GRRRR8)
R.I.P. Chris (Panzer Leader)
i have a big 3 car garage
Installed a new set of Whiteline of End Links last night (fronts). Tonight is the back set.
Went to lunch with my daughter and by the time I got to HEB 4 miles down the road it is so full of road dust I hate Black cars
Had to get use to driving it again after it sitting for a month
Where are you looking Ray? What towns?
Was finally able to drive her again. She arrived this morning.
Good luck Ray. Cibolo & Schertz are nice areas also that are just north of SA and not too far from Converse.
My bro and his now ex-wife lived in Cibolo for a while. Lots of new subdivisions with homes with two car garages.
Sent from my iPhone using Tapatalk Pro
Terry Scott
